August 27, 2025, 12:47:47 PM *
Author Topic: she wont restart  (Read 613 times)
HurstRob
« on: May 01, 2016, 11:41:57 AM »
I need some trouble shoot advice from Valk geniuses.
last summer I started a desmog, carb rebuild, ,,long story short; got very busy and now back to it.
I replace the fuel line and installed an electric fuel shut off.
I pulled plug and checked for spark,,got it, also checked plug for fuel seem to have that on right side, not left side
Also have fuel dripping from right side exhaust drain hole.
Not a spark or pop, battery new, I can hear the fuel shut off switch kick in and out
« Reply #1 on: May 01, 2016, 05:28:03 PM »
Could it be moisture, not fuel? Maybe pull the plug and see if it is wet.
Also, a bad battery may have enough juice to turn the engine, but not fire up the coils. Get your daily driver (not running), and jumper it to the bike, and then try to turn it over again.
Try a volt meter on the battery if you have one. Before, after the jump, and hopefully after you get it running.
