February 11, 2026, 08:51:04 PM *
Author Topic: Petcock After Desmog?  (Read 804 times)
hueco
WACO,TEXAS
« on: May 05, 2016, 09:04:58 PM »
What are the options for the petcock after desmog? Forgive my ignorance. Thanks.
Steel cowboy
Spring Hill, Fl.
« Reply #1 on: May 05, 2016, 09:57:11 PM »
you can reconnect the vacuum line from #6 manifold (left side rear) or go with a vacuum-less Pingel shut off.
2001 black interstate
2003 Jupiter Orange wing
Cracker Jack
« Reply #2 on: May 05, 2016, 10:02:20 PM »
Desmog doesn't change the options. If you stay with OEM (or aftermarket) with vacuum you will still need the vacuum line to one of the intake runners. Number 6 is what is used from the factory. cooldude
« Reply #3 on: May 06, 2016, 07:21:21 AM »
You can also de-vacuum the OEM petcock which is what I did.  Then it operates as a manual petcock. I just leave mine on aince I have a Dan-Marc.  R&M Works has instructions here:
http://rmworksinc.com/files/a-Belly_tank_instruction_manuel-pdf.pdf
