February 11, 2026, 08:50:55 PM
Radiator hoses
Topic: Radiator hoses (Read 832 times)
Radiator hoses
May 06, 2016, 07:56:34 AM »
Looks like I'm needing to replace upper and lower hoses. Any suggestions on part numbers needed and best place to order (cheapest and fastest shipping) are appreciated.
Edit: Found 'em at Procaliber.com
Last Edit: May 06, 2016, 11:10:08 AM by Valkorado
Re: Radiator hoses
May 06, 2016, 11:53:05 AM »
How do these prices compare?
http://www.ronayers.com/oemparts/a/hon/506cb5fcf870023420a416d7/radiator
Re: Radiator hoses
May 06, 2016, 12:02:50 PM »
Procaliber slightly less, BUT they wanted around $20 for shipping. I'm holding off until I can get to that upper hose clamp screw. I pulled the radiator forward but that hose clamp screw is angled
just
out of my reach. Need a flex bit driver extension and I may be able to get to it...
Re: Radiator hoses
May 06, 2016, 05:39:40 PM »
Replacing because?
Most have reported finding the hose leak a little, and after re-tightening the clamp, no more leak.
I would rather remove entirely, clean the fitting surface, a little lube (spit on it or a little soap), and re-attach.
Cost; $0.00
Time; Priceless
