February 11, 2026, 08:50:51 PM *
Author Topic: Clutch lever  (Read 797 times)
TW
East Texas
« on: May 06, 2016, 07:23:09 PM »
I have a 97 Valk with approx 59,000 miles on it.
I noticed tonight that each time I pulled the clutch lever that it made a noise that sounded like dry rubber. Is there something in there that needs to be replaced or that needs some type of maintenance?
I am not terribly mechanically inclined but would appreciate any reply.
Thanks in advance,  Elliott
« Reply #1 on: May 06, 2016, 08:03:48 PM »
Periodically you remove the handle, lube the brass insert and the pivot point.  I also Emory cloth the curved part of foot that contacts the pushrod to make it smoother
TW
East Texas
« Reply #2 on: May 06, 2016, 08:42:03 PM »
Thank you sir.
 I just looked at my Clymers manual and I should be able to do that.
Thanks again
Elliott
