February 11, 2026, 08:51:04 PM
Installing truck stacks
Topic: Installing truck stacks (Read 981 times)
Dak44312
Akron, OH
May 08, 2016, 06:32:59 AM »
Necessary to fill the exhaust tip bolt holes? I can hear them leaking with the stacks off, just wondering if the stacks fit so tight that it won't matter?
Re: Installing truck stacks
May 08, 2016, 06:46:52 AM »
I had to rap mine on with a 2 X 4 (over the tip ends) with a rubber mallet. Pretty tight fit, even after cleaning up all the carbon/crud.
I drilled all three (existing) holes in my new (Air Flow) tips to reuse the bolts and holes.
After the job was finished, I figured those tips would stay on just fine with one bolt (each) (the inside one, so it doesn't show).
I would not use
no
bolts because a few bad bumps (or something) could cause one to depart the bike.
If you don't use all three bolts, I think the tips are so snug, you will not hear any gas escaping the unused muffler holes. Course I don't know what tips you are using.
Last Edit: May 08, 2016, 06:49:22 AM by Jess from VA
Dak44312
Akron, OH
May 08, 2016, 06:50:12 AM »
I know they are a tight fit, so I was planning on NOT using any hardware. I am using the 36" stacks with Grumpys tips.
May 08, 2016, 06:55:09 AM »
Well, I was describing just replacing my std 18" tips, not full length stacks. I have no experience with those. It seems to me using less hardware/fasteners (with a super snug fit) would be OK, but having at least one fastener somewhere would be a good safe idea.
Besides hard bumps, there could be an issue with big temperature changes, like taking the bike out on a cold day, then firing it up hot (with resultant expansion).
I still don't think it necessary to fill the muffler holes.... and I try to leave things alone where it is possible you or someone else may want to go back to original parts sometime down the road..
Last Edit: May 08, 2016, 06:58:42 AM by Jess from VA
