March 16, 2026, 09:26:45 AM *
Author Topic: It's time....................  (Read 1634 times)
Pappy!
Central Florida - Eustis
« on: May 08, 2016, 08:35:30 PM »
Started the routine maint. this weekend for the upcoming ride to Inzane.
Went completely through the front brakes with cleaning, new seals, new pads while I was there and new fluid. New coolant and oil change so far. Did a deep cleaning and shining that would make Sixlow step on his tongue.
This evening I ran it over to a little restaurant on Lake Dora that I met Bronxy and Billy Boy at a few weeks ago. Stuck the trombones in the Mark T pipes...what a wicked sound!
TJ
Lake Placid , Fl.
« Reply #1 on: May 09, 2016, 07:08:25 AM »
Pappy!
« Reply #2 on: May 09, 2016, 07:17:00 AM »
Almost forgot.....Put in a quart of this as well. Never hurts.
Bronxboy
Tampa Bay FL
« Reply #3 on: May 09, 2016, 10:09:51 AM »
Yeah my headlights are due for a oil change as well, and replacing my J Rod. I went thru my bike as well after getting back from Myrtle, did oil change and routine checks.
Hey Pappy check out the 1500 tech board, I put up a post on some oil I found under the bike.
Maybe u can concur this for me?
sixlow
St. Augustine, Fl.
« Reply #4 on: May 09, 2016, 04:28:21 PM »
Wow Pappy that bike sounds very clean and shiny, let's get ours side by side after motoring to Morgantown and see if we missed any spots !
Nick have you check that leaky muffler bearing ?
Pappy!
« Reply #5 on: May 09, 2016, 06:30:22 PM »
So.....this is going to be like one of those "I'll show you mine if you show me yours" events?
Mike....never knew you cared! As long as you don't turn into "Sixhigh" that will be fine.
Pappy!
« Reply #6 on: May 09, 2016, 08:37:09 PM »
Bronx.........read it but not enough to go on yet. Clean the shock and the rear caliper really well. See which one it turns out to be. Still plenty of time.
sixlow
St. Augustine, Fl.
« Reply #7 on: May 10, 2016, 06:28:30 AM »
Didn't think it was gonna go there but LoL, I guess what I meant was by the time we both get to WV. There won't be any clean spots left.  Wink
Bronxboy
Tampa Bay FL
« Reply #8 on: May 10, 2016, 12:18:21 PM »
Everything is all dry and wiped down, going on a long ride Saturday, so I will check it out when I get back. cooldude
