February 11, 2026, 10:24:17 PM *
Author Topic: 205/ 75/16?  (Read 1135 times)
BIG--T
The Twilight Zone
« on: May 09, 2016, 04:38:26 PM »
Has anyone run a 205/ 75/16 or even tried? I know it'll be tight....If it fits. Undecided
bill-jr
VRCC # 35094
murfreesboro
« Reply #1 on: May 09, 2016, 04:40:24 PM »
205-60
99' Black tourer
« Reply #2 on: May 09, 2016, 04:52:29 PM »
I haven't looked for any. Do you have any in mind in particular ?
« Reply #3 on: May 09, 2016, 05:59:44 PM »
Have you run the numbers through a tire calculator?
See what a 225/65 diameter is, and then your 205/75.
« Reply #4 on: May 09, 2016, 06:17:32 PM »
no such size??
https://tiresize.com/chart/
« Reply #5 on: May 09, 2016, 06:53:15 PM »
          I've had 2 different 205-65-16s on y I/S. I believe with stock length-13"-shocks that the 205-65-16 is right at the limit of what will fit without getting into some modifications to the existing structures. And for me anyway the 205-65-16s were very rideable. RIDE SAFE.
« Reply #6 on: May 09, 2016, 07:00:21 PM »
It'll probably fit if you remove your fender, and leave it off.
« Reply #7 on: May 09, 2016, 07:39:50 PM »
Tire Size Calculator
https://tiresize.com/calculator/
205/75-16
dia 28.1"
revs/mile 718
225/65-16
dia 27.5"
revs/mile 733
I didn't check to see if a tire was available.
As for width, 205 mm or 225 mm. It's 20 mm narrower, so nothing wrong there.
« Last Edit: May 10, 2016, 04:40:59 PM by gordonv » Logged
