February 11, 2026, 10:24:18 PM *
Author Topic: Diamond star modulator.  (Read 795 times)
Crush
Upstate South Carolina
« on: May 12, 2016, 05:38:32 PM »
I am installing a headlight modulator in a 99 IS. Which wire is the hot horn wire? I do NOT have a manual yet.. TIA Cool
big poppa pump
San Antonio, TX
« Reply #1 on: May 12, 2016, 07:14:24 PM »
Why are you using the horn wire for a headlight modulator?
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Crush
« Reply #2 on: May 12, 2016, 07:55:08 PM »
Diamond star has a green wire that ties into the horn. When you hit the horn it will flash 3 times if you are not in modulation mode, and will flash between high and low 3 times if you are in modulation mode.
big poppa pump
San Antonio, TX
« Reply #3 on: May 12, 2016, 07:59:33 PM »
Ah! Get the manual here.
http://www.valkyrienorway.com/1520manual/valkyriegl1500.zip
VRCC#35870
VRCCDS#0266
h13man
Indiana NW Central Flatlands
« Reply #4 on: May 14, 2016, 04:56:10 AM »
Blue/Brown taps into other Black hot leads. Light Green goes directly to the horn as a one of the Black wires that connect to the horn. The reason I'm inputing is I'm relocating my horn under the triple tree  with a custom made SS bracket thus if there is any misread on my part  Shocked I'm sure somebody will give us a head up.  Smiley
« Last Edit: May 14, 2016, 04:57:41 AM by h13man » Logged
