February 11, 2026, 10:24:19 PM
Splines and Axle
Topic: Splines and Axle (Read 952 times)
cogsman
Newmarket, Ontario, Canada
Splines and Axle
May 14, 2016, 09:12:21 AM »
Hi All,
I'm hoping the answers are "yes":
Is this the right stuff for the final drive splines? I got it at Honda in Newmarket for $20 tax in:
Is this fine to use on my bearings and axles?:
big poppa pump
San Antonio, TX
Re: Splines and Axle
May 14, 2016, 09:45:50 AM »
Yep! You're good.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
PAVALKER
Pittsburgh, Pa
May 15, 2016, 09:57:06 PM »
Far as the wheel bearing grease goes....that will work fine. That Moly 77 says grease, not paste....and paste is what you want on the splines. That might be new stuff, I think they recently changed, but there is a diff between moly paste and moly grease.
John
