February 12, 2026, 12:11:43 AM *
Author Topic: Battery connections were loose!!UPDATE Replace the Start button or clean it?  (Read 1868 times)
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« on: May 18, 2016, 07:00:23 AM »
If I replace it do they just sell the part needed or is it an entire housing assembly?
The new switch came in but with the advise listed here I decided to check the battery connections first. Yep!  They were loose. 10mm wrench and it fired right up!!
« Last Edit: May 27, 2016, 06:22:00 PM by _Sheffjs_ » Logged
« Reply #1 on: May 18, 2016, 07:17:49 AM »
It's the entire housing, both halves, including the kill switch, the start button, and the wiring harness to the connector in the headlight.
Danny McMillin
Hattiesburg, MS
« Reply #2 on: May 18, 2016, 07:30:03 AM »
Replace, Replace, Replace! I danced with mine for 6 years, cleaned, worked fine for weeks or months, and clean again. Left me stranded several times on road, embarrassing when riding in groups. Never knew when I hit the start button, what was going to happen. BBF changed mine out at Inzane last year! Bought the entire switch , but changed out internals. My housing was chromed. Trouble free since, no more worries!!
_Sheffjs_
Sarasota FL
« Reply #3 on: May 18, 2016, 10:34:40 AM »
Ordered    cooldude
« Reply #4 on: May 18, 2016, 11:57:52 AM »
I've cleaned mine twice in 18 years and 153K miles. Still works perfect.
« Reply #5 on: May 18, 2016, 01:08:13 PM »
People have to keep messing with it because they dont fo the job right.  Its not just cleaning...its making sure it works properly.  Even my brand new one that I needed to order had to be fixed before it worked properly.
« Last Edit: May 18, 2016, 01:11:42 PM by Chrisj CMA » Logged
98 VALK
« Reply #6 on: May 18, 2016, 03:27:50 PM »
I have a 1998 tourer & it has original everything . Nothing to date has ever failed on this motorcycle. I did order the switch,starter stop complete assy the other day. Part # 35013-MZ0-020  $93.99 and a radiator cap also. No telling how many times that starter button has been hit. Amazing how these valk's were built to last.
« Reply #7 on: May 18, 2016, 03:41:20 PM »
Ordered    cooldude
Jerry, hope you didn't pay more than $61.84.... Procaliber.com
Now, listen to your Dutch Uncle.....install a relay as instructed in the link below. It can be installed in the headlight bucket and it removes the heavy current load off the start switch. Makes huge difference in the longevity of that rather important part of the bike. In the link, scroll down to the Start Switch Safeguard section and follow the steps. Sherry should be able to have it done in less than an hour.  2funny
Seriously, it's easy, but if you need help just holler.  cooldude
http://www.rattlebars.com/mtz/starter.html
« Reply #8 on: May 18, 2016, 03:41:50 PM »
Where did you order it?
ProCaliper.com
SWITCH SET, STARTER STOP
35013-MZ0-000
$61.84
h13man
Indiana NW Central Flatlands
« Reply #9 on: May 18, 2016, 06:05:13 PM »
Replaced mine 1 1/2 ago and since added a Smart Switch to alleviate all extra voltage passing thru the weak switch assembly. And yes you can make your own "Smart Switch" but the original is hassle free plug n' play.
desertrefugee
Chandler, AZ, USA
« Reply #10 on: May 18, 2016, 07:52:47 PM »
Properly cleaned, they'll provide another coupla decades of service - unless heavily pitted.  Usually, it's just a good cleaning that's needed..
Also, a faulty starter button should NEVER leave you stranded.   As with any vehicle with a starter relay, it's a pretty simple matter to jump the load terminals to get started.  Embarrassing that you have to pull the side cover, but not as embarrassing as calling for a tow for something so simple.
'97 Bumble Bee,  '78 GL1000, '79 CBX, '78 CB750F, '74 CB750
_Sheffjs_
Sarasota FL
« Reply #11 on: May 18, 2016, 07:54:06 PM »
Ordered    cooldude
ok Dutch Uncle, I fully understand and wireing is one of my strong suits.
_Sheffjs_
Sarasota FL
« Reply #12 on: May 18, 2016, 07:56:37 PM »
I have a heavy (6g) u shaped wire just for that, especially until the part comes in.  I was wondering why no one mentioned it before.
hukmut
Stone County, Mississippi
« Reply #13 on: May 19, 2016, 07:43:19 AM »
I have one of those u shaped wires jumping my clutch switch that failed. I always pull in the clutch lever each time I start anyway. cooldude
Ride safe...
WintrSol
Florissant, MO
« Reply #14 on: May 19, 2016, 10:17:16 AM »
Ride safe...
While I do the same, it is not needed if the bike is in neutral; only in gear with the side stand up.
CoachDoc
San Diego, CA
« Reply #15 on: May 19, 2016, 11:39:48 AM »
Agree 100%. I did the same cleaning mambo with mine for a couple of years, then finally replaced. Should have done it much sooner.
CoachDoc
'97 Valkyrie Standard
'05 Goldwing
'74 CB550K
Daniel Meyer
The State of confusion.
« Reply #16 on: May 19, 2016, 11:42:43 AM »
Cleaned, freed up the springs, and lubed mine...180,000 miles ago...
CUAgain,
Daniel Meyer
98 VALK
« Reply #17 on: May 19, 2016, 02:23:34 PM »
Hook  I bought the switch from HAlls Motorsports in Mobile Al. I had some other work done to it and just let them put the switch on also. Good to know about the other vender. I'll use them next time for sure. Thanks for the tip.
_Sheffjs_
Sarasota FL
« Reply #18 on: May 21, 2016, 01:19:40 PM »
The new switch has not come in yet and we took the 1800 out today. But I did start the 1500 this morning and the lights did not come on at all then I turned the key off and back on and I had lights and it started.   Let her run for a while and then left for our ride on the 1800.  Come back and now the key will not turn on anything.  No time to fool now moreover next week when we come back up. Should have the switch by then but not sure if the start button is the issue now.
zzed28
Midland Michigan
« Reply #19 on: May 21, 2016, 09:40:52 PM »
I had almost precisely the same thing, check all your battery connections, the cable attachment bolts were loose on the battery on mine, how embarrassing.
desertrefugee
Chandler, AZ, USA
« Reply #20 on: May 22, 2016, 07:18:25 PM »
 2funny 2funny
Oh man.  Same here.  Exact same symptom.  Loose battery connections AT the battery.  I wasn't going to confess, but since I'm not the only one.   Check 'em.
_Sheffjs_
Sarasota FL
« Reply #21 on: May 27, 2016, 06:19:19 PM »
Thanks for the tip cooldude
_Sheffjs_
Sarasota FL
« Reply #22 on: May 27, 2016, 06:19:58 PM »
 2funny 2funny
pocket aces
Tampa, Fl
« Reply #23 on: May 28, 2016, 12:44:43 PM »
Could some explain in detail how to jump the load terminals. This noobie needs some help. Thanks!!
_Sheffjs_
Sarasota FL
« Reply #24 on: May 28, 2016, 05:16:23 PM »
A pair of pliers or I use a 8 gauge wire bent in a U shape I keep handy. Take the right side cover off expose the starter relay and jump the two large terminals. Key is turned on and bike in N, kill button in run.
Sorry not near bike for any pics.
