January 29, 2026, 06:18:39 PM *
Author Topic: Brillo pad to my pipes?  (Read 2119 times)
Printer Mike
Eatonton, Georgia
« on: September 22, 2009, 06:08:26 AM »
My Cobra pipes have dark blue stains in the header area. I thinkin' they would look better clean and dull than the way they look now... crazy2
Never give up!
« Reply #1 on: September 22, 2009, 06:14:18 AM »
They will just turn blue again.........I have convinced myself that the blue looks good, it has the look of power.......I now like the blue, but then again I have a red and white so blue goes  cooldude
Cliff
Manchester, NH
« Reply #2 on: September 22, 2009, 07:26:52 AM »
I also quit fighting the blue on my cobras,,, it ALWAYS comes back.
VRCC # 29680
DFragn
« Reply #3 on: September 22, 2009, 07:57:49 AM »
You could have them ceramic coated.
My Viking headers are ceramic coated and hold up to long lengths of high temps. High enough that while syncing my carbs my alternator cover melted.
I don't mind the semi gloss of the ceramic. I would have preferred chrome, but I know I wouldn't have like blue/black.
aviaator
No. Virginia
« Reply #4 on: September 22, 2009, 08:00:40 AM »
I don't have any blue on either of my Valks' exhaust.
But I understand that a good way to remove it is to use [any] good metal polish with 0000 steel wool.  Do not use brillo.   You will ruin the pipes.
'97 Tourer
'00 I/S
VRCC 27632
Southern Cruisers Manassas, VA Chapter
« Reply #5 on: September 22, 2009, 08:29:09 AM »
Blue on exhaust pipes is oxidation of the chrome plating and any removal of the blue will encompass removing of the chrome plating to some degree.
Use of abrasives (chemical or other) is the only recourse to remove the blue.
Keep in mind that in removing some of the chrome plating, the thickness of the plating will become less, exposing the pipes to possible rusting of the base layer.
At a minimum, the chrome will become dulled.
DFragn
« Reply #6 on: September 22, 2009, 10:28:07 AM »
Stock headers are doubled walled thereby essential eliminating bluing.
It's the single wall aftermarket chrome headers that turn.
V98
« Reply #7 on: September 23, 2009, 06:50:23 AM »
I've heard good things about a product called BLUE JOB. You can get it online or at Hardley dealerships.Last time I looked it was $12. Good luck.
