February 11, 2026, 10:45:13 PM
Brake light conversion
Topic: Brake light conversion (Read 1045 times)
Paladin528
May 19, 2016, 03:18:04 PM »
So I picked up an entire rear fender assembly including all of the lights plus a few extra from standard to install on my IS. Problem is the IS harness connector is different than the STD/Tourer.
I assume I need the Standard/Tourer harness from the right side panel to the rear fender connector to make this work. If I do that there is still one connection that escapes me.
on the IS there are 4 wires to the rear fender and on the STD/Tourer there are 5 wires (brake light I know) where is the best place to make that connection? and where is the best place to get the harness?
Paladin528
Re: Brake light conversion
May 19, 2016, 03:24:27 PM »
ok so i ordered the harness for like $8
now it is just the connections.
