February 11, 2026, 10:43:36 PM *
Author Topic: Splines and Moly leaking???  (Read 1057 times)
jim@98valkyrie.com
Wayne, PA
« on: May 20, 2016, 09:28:43 AM »
Hi guys,
Been around the board for many years. Had to store my '98 Tourer for two years due to a knee injury. Just getting her back on the road. Have done all the fluid changes etc. and she's running at 95%. Now, I need new tires. Pulled the rear wheel last night and found the Moly that I had put in a few years back (refer to two year storage above) has leaked out. At that time, I changed all three O-rings.
In the meantime, I had a rear blow out on the road and was forced to get a new rear tire at a stealer. Besides the fact that they installed the tire on the incorrect direction, I don't know what, if anything else they did wrong.
I purchased a new set of O-rings from Rich @ Ecrater and plan on installing them when the tire goes back on. Any thought on the Moly leakage here in the pic? Will installing the new O-rings correct this? At least the splines aren't dry!!
Jim
« Last Edit: May 20, 2016, 09:50:03 AM by jim@98valkyrie.com » Logged
« Reply #1 on: May 20, 2016, 09:30:01 AM »
That's completely normal.  Looks great.  Do whatever you did last time again cooldude
Bagger John - #3785
« Reply #2 on: May 20, 2016, 09:36:53 AM »
What Chris said.
« Reply #3 on: May 20, 2016, 09:37:15 AM »
Yup, picture shows well-lubed splines.  Normal.
jim@98valkyrie.com
Wayne, PA
« Reply #4 on: May 20, 2016, 09:40:06 AM »
Thanks guys!!! Glad to hear it is normal.
Michvalk
Remus, Mi
« Reply #5 on: May 20, 2016, 09:55:06 AM »
Yeah, totally normal. If you put just the slightest extra amount of grease on the splines, it will seep past the o-ring, then you get the runout that you see. Mostly from pushing the o-ring into the spline. No big deal, except for the mess you see. Better too much than too little cooldude
« Reply #6 on: May 20, 2016, 10:12:34 AM »
Agree with everyone else. Plus it's nice to see a pic of good splines for a change.  cooldude
« Reply #7 on: May 20, 2016, 07:57:20 PM »
And don't forget to change out your tire valve.
Jake Wilson 90' metal valve stem (my link isn't working, site down?)
