November 27, 2025, 06:13:29 AM *
Author Topic: Gl1500IS Stalling/unsteady idle when warm and fan is running  (Read 954 times)
Memor86
Tampico, Mexico
« on: May 21, 2016, 07:53:02 PM »
Hello folks, I rebuilt my carbs and bench synced them, set the pilot screws at the recommended turns here. I can't remember exactly but somewhat 2 and 1/4 or 1/2 turns out.
It runs great at apeed, at idle when cold it randomly pops on the exhaust, but the rpm does not jump up and down, besides the poping it sounds very smooth. No smoke or funny smells on the exhaust.
the bike is hot and is on idle speed it will have random hiccups but goes smooth again. When the fan kicks in, that hiccup makes the engine to stall. I have tried to compensate it by raising the idle speed to 1000 rpm but that's not the proper fix and it still makes the engine to stall but not so often.
Bike has 90kmiles stock exhaust non-california edition and gas k&n air filter with the black foam thing on it. (I have not cleaned it)
At speed runs great and powerful but the idling is annoying and sometimes stalls at the red lights. I guess the problem lies in the pilot screw setting.
Ps. I've checked the choke, it works fine and is not stuck.
Any suggestions??
« Last Edit: May 21, 2016, 07:57:22 PM by Memor86 » Logged
« Reply #1 on: May 21, 2016, 08:20:00 PM »
I'm not the best with carbs, but it sounds like a vacuum leak to me.
How about the intake tubs O-rings? Spray some product at the tub/engine, and listen for a change of rpm (WD40/ether/???)
Firefighter
Harlingen, Texas
« Reply #2 on: May 21, 2016, 08:24:54 PM »
Check battery voltage at battery and then at frame, could be bad frame ground. In other words, while it is acting up, use voltmeter on battery and find voltage then touch negative lead to frame and see if voltage is the same or not. My IS had same problem and I ended up running a jumper wire from battery negative to frame and it was cured. Ignition grounds through the frame, but battery ground wire attaches to the engine.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
WintrSol
Florissant, MO
« Reply #3 on: May 21, 2016, 08:50:00 PM »
Just FYI, the coil on the left frame tube, under the tank, has a harness ground wire connected to it, and one of the holes the coil bracket bolts go through is cleaned of paint, so the coil bracket makes that ground go to the frame. I don't know about the other coils, but, whenever I open a connection like this, I clean the bracket and frame contact areas with a soft brush and contact cleaner, just to make sure I have good grounds. If it is a ground issue, that would be a good place to check.
« Reply #4 on: May 22, 2016, 12:20:09 PM »
Sounds like the carburetor synchronization is the culprit.  That's my first choice.
WintrSol
Florissant, MO
« Reply #5 on: May 22, 2016, 04:44:02 PM »
Yeah, start with the carbs; more likely than grounds, and easier, IMO, to sort out.
Earl43P
Farmington, PA
« Reply #6 on: May 23, 2016, 06:49:49 AM »
Humor me...
Connect a set of jumper cables to the Valk battery and your car (don't start your car, just connect it).
Run the bike until the fans come on. Result?
I think your alternator is the culprit, not carbs!
Specifically, I think the brushes are worn and low rpm fails to generate enough amps for spark AND fans.
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
« Reply #7 on: May 23, 2016, 10:07:19 AM »
+1 Logical to me too.
Can also do the same with a meter too.
Might be like my alt was, brushes sticking in their settings. Wore away till there was no more contact (didn't move), and no more power. Removed, cleaned, and worked fine again. 30K miles left (estimated) on the brushes.
