February 11, 2026, 10:43:34 PM *
Author Topic: Wanted light socket!  (Read 1068 times)
Jym777
Silver Springs Fl
« on: May 24, 2016, 04:56:48 PM »
Just today I noticed my indicator light for signal light on top of the headlight bucket went out ck bulb it was ok the socket was the culprit, all three are the same l believe, tried cleaning it up but with no luck, there is power going to it, so if anyone has one from parts bike or whatever l would much appreciate it just let me know how much! Thanks,  Jym...
Roidfingers
Tuscaloosa, Alabama
« Reply #1 on: May 25, 2016, 05:40:28 AM »
Number 18 I believe.
http://www.dealercostparts.com/oemparts/a/hon/506cb5f3f870023420a416b8/headlight
indybobm
Franklin, Indiana VRCC # 5258
« Reply #2 on: May 25, 2016, 06:13:03 AM »
Have you made sure that the headlight hi-beam is turning on?
Inside the headlight bucket, the green wire from the hi-beam indicator goes to a ground splice, #35 on the schematic. Have you used a meter to check for the ground connection at the green wire of the hi-beam indicator socket?
http://www.rattlebars.com/valkfaq/schematics/rpage04.html
edited
So many roads, so little time
VRCC # 5258
