January 29, 2026, 06:19:04 PM *
Author Topic: Electric Horns  (Read 2368 times)
valk2001
There is nothing like riding a Fat Girl....
Darlington, SC
« on: September 22, 2009, 11:55:06 AM »
I bought a set of electric horns at an auto parts store and mounted near where the OEM horn was located.  The problem is that they filled with water in all the rain we had on the Trail of Tears ride over the weekend and sounded like a frog blowing his nose after only a new miles.  I do not want an air horn but like the sound of my wife's 2006 Goldwing horns.  Any suggestions as to what to buy next?  I have heard that some have success mounting new horns in the pods on the IS.  Mine is a 2001 Interstate.
Mikey
Winona, MN
« Reply #1 on: September 22, 2009, 12:10:25 PM »
I bought my Valk and found out the first time i put it on a jack that it has (4) car horns belly mounted. The guy before me bent up some tin, ran the wires, and screwed the whole deal to a crossmember. I love it, it's clean, and loud.
Remember folks, street lights timed for 35 mph are also timed for 70 mph
VRCC# 30782
« Reply #2 on: September 22, 2009, 12:42:08 PM »
Does it look anything like this  Grin
-Mike "BigBF quad horns"
Mikey
Winona, MN
« Reply #3 on: September 22, 2009, 12:43:44 PM »
Pretty much! But mine are all angled forward and out.
VRCC# 30782
Hog Killer DS0048
Tucson, AZ
« Reply #4 on: September 22, 2009, 04:43:55 PM »
I had a Stebel horn on mine and liked it alot.
Disco
Republic of Texas
« Reply #5 on: September 22, 2009, 05:26:54 PM »
Stebel Compact Nautilus   cooldude
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
Tropic traveler
Silver Springs, Florida
« Reply #6 on: September 22, 2009, 06:07:10 PM »
Mounted a pair of 2003 Lincoln Town Car horns on all 3 of our Hondas. All swingarm mounted & used a relay. The reason I used Town Car horns was the perfect V-shaped bracket that mounts them. All you have to do is make sure you rotate the horn openings AWAY from the back tire. Don't ask me how I know that! Embarrassed Welded a 5/16ths x 1" bolt & a spacer to the swingarm, fasten the horn assembly on with a nylock nut, wire 'em up and hit the LOUD button!  cooldude
Not too loud so as not to startle our large population of "senior drivers" down here. No air horn wind up either, just an instant, familiar car horn sound. With the horns unshrouded by sheetmetal under the bike, car horns are significantly louder than in the car.
Saved my bacon more than once!!
« Last Edit: September 22, 2009, 06:09:06 PM by Tropic traveler » Logged
'13 F6B red for Kim
sugerbear
wentzville mo
« Reply #7 on: September 23, 2009, 08:49:03 AM »
i bought a pair from a parts store, mounted them under the bike aimed sideways. no water problems.
Ken Tarver
North Mississippi
« Reply #8 on: September 23, 2009, 09:09:04 AM »
this bike belongs to my son now....when i had it put on a pair of Stebel TM80 Magnum electrics.
Rocketman
Seabrook, Texas
« Reply #9 on: September 23, 2009, 12:16:41 PM »
I've put a Stebel Nautilus in the right side pod, even though there's a voltmeter in the same pod.  I imagine it would be difficult if you have the pod lights as well, though.  You still have to point it downward.  The pod doesn't protect it quite enough if you get in a real hard rain.  I had the gargling frog sound come out of mine when I first put it on pointing upwards.
As for mounting, I just used a homemade bracket, and bolted it up to one of the radiator bolts.  The radiator is rubber mounted, so make sure you ground it separately.  Might take a few tries to get it to sit properly, and let the pod fit around it, but sounds great after you get it.
I want to put another in the left pod, just for added volume, and symmetry.  The sound definitely is louder on the right side, and I want to blast people on each side if necessary.
