Kidd
« on: June 01, 2016, 12:37:29 PM » |
2 Orange & White stickers on gas tank How to remove them without messing up paint ??
havoc
VRCC #36861
Calgary, Alberta CA
« Reply #1 on: June 01, 2016, 12:45:40 PM » |
this worked great for me, but not sure how it will for you:
i used my thumbnail to break the corner seal of the stickers so i could start peeling. much of it came off including the adhesive...but the trick was how to get rid of that damn sticky adhesive that was left.
i rubbed those spots with my fingers (you will get slight friction burn). after that i used lint free cloth with Turtle wax and all is good.
i'm sure someone posted about this in the past and that had a chemical they used but i can't quite remember.
"Not all those who wander are lost" - J. R. R. Tolkien
Kidd
« Reply #2 on: June 01, 2016, 12:54:06 PM » |
I am afraid I will remove a piece and will be left with a piece that will be forever there , or left with an abundant amount of scratches trying to get the last piece removed
It reflects into the OEM Hondaline windshield
« Reply #3 on: June 01, 2016, 01:39:12 PM » |
Trick is not to damage the paint underneath (or at the edges), which will be better than the rest of the paint.
I'd slime them with Goo Gone or other non-corrosive for awhile. Get a corner up and take as long as necessary to slowly peel it off (pull at 180* and goo gone underneath as it comes up). Then use cleaner wax or gas to get the rest of the goo off.... light (never hard) rubbing. Clean off gas. Wax again.
« Reply #4 on: June 01, 2016, 01:49:17 PM » |
When my bike was new, my wife peeled off the stickers, and I wiped (didn't have to scrub or anything) the goo residue off with a rag soaked in linseed oil, it worked great.
I think the longer you leave your stickers on, the harder they will be to cleanly remove.
My 1500 was old when I got it, and the lawyer stickers were still on the tank, I got them off, but it wasn't near as nice as getting new stickers off...
Kidd
« Reply #5 on: June 01, 2016, 01:56:42 PM » |
Okay , so , I am thinking , if I set it out in the sun to heat up , should make it easier coming off
hungryeye
« Reply #6 on: June 01, 2016, 02:10:20 PM » |
Use a heat gun on low and at least a foot away and keep it moving, picking at it with your fingernail will tell you when its ready, alcohol, WD 40 or linseed oil as Mike said on a rag will remove any residue, wax to complete.
2014 F6c Red ish 1983 GL650 cream puff 2010 Spyder RS
we DRIVE our cars, we RIDE our motorcycles!
Kidd
« Reply #7 on: June 01, 2016, 03:35:14 PM » |
Alright , done , I actually had a heat gun , took a total of 5 minutes or less Still , a little glue left from the smaller sticker 3 bikes ago , I bought a Vstrom from original owner who partially scraped his off with a finger . I was afraid mine would end up like his . I guess he worked on it at stop lights .
dans2014
« Reply #8 on: June 01, 2016, 09:13:14 PM » |
I took mine off as soon as it came home. came off easy and waxed. If they have set in the sun, go to a body shop and get an opinion b4 screwing it up
Dan's 2014 Valkyrie
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #9 on: June 02, 2016, 02:35:14 AM » |
Remove sticker with a heat gun or a hairdryer. Remove adhesive easily with WD-40 and a rag
blackvalk
« Reply #10 on: June 02, 2016, 04:18:53 AM » |
Regular cooking oil (corn oil) removes most adhesives
