February 12, 2026, 12:11:49 AM *
Author Topic: Fork Fluid ?  (Read 1166 times)
Brian
Monroe, NC
« on: June 02, 2016, 03:01:50 AM »
Hey guys, I am about finished with rebuilding the forks on my 97 standard. While filling each tube with the Honda 10w suspension fluid I read the fine print on the back of the bottle. It states that their fluid can be used where ATF is recommended. So my question is, is their fluid repackaged ATF at a much higher price? Angry
« Reply #1 on: June 02, 2016, 03:31:53 AM »
I don't think any of us have had it chemically analyzed, but
I know I've had good luck with Honda fork oil...
« Reply #2 on: June 02, 2016, 08:29:36 AM »
there is zero industry standards when it comes to fork fluid weights.  ATF is a known to be a 7.5w oil.
The '81 CB900C uses ATF in the forks and shocks.
I posted some info before about fork oil, suggest looking for the posts.
« Last Edit: June 02, 2016, 10:06:08 AM by 98valk (aka CA) » Logged
« Reply #3 on: June 02, 2016, 09:14:55 AM »
Many forks use ATF. ATF is 7.5 wgt so the difference is marginal.
Whether Honda fork oil is ATF, I don't know. But, I wouldn't think twice about using it in a fork, but, certainly wouldn't put it in my Vehicles transmission.
« Reply #4 on: June 02, 2016, 10:05:40 AM »
Pat thanks for adding that 7. , I will mod my typo.
« Reply #5 on: June 02, 2016, 10:19:21 AM »
Oh, I didn't put that in as in any way to disagree or disrespect anything you said.  ATF has always generally been accepted as far as I know to be 7.5. The way things have changed there is probably ATF in some other close viscosities. I just meant that ATF could be used if a bit lighter weight oil was wanted than 10 wgt.
« Reply #6 on: June 02, 2016, 11:30:39 AM »
didn't take it that way. Always pay attention to what u write, u have more hrs in the shop than I do.
 My mind was still back in the '80s when it was 5wt and I was rebuilding the forks and shocks for my CB900C, but now the modern ATF is pretty much 7.5wt. I don't think any of it is 5wt today.
« Reply #7 on: June 02, 2016, 01:25:43 PM »
Your mind is in the 80s. Heck, thats a good place for it. Hmmm, JoAnn keeps saying mine is in the gutter.  Smiley
« Last Edit: June 02, 2016, 01:27:52 PM by Patrick » Logged
Brian
Monroe, NC
« Reply #8 on: June 03, 2016, 02:19:29 AM »
Thank you all for the posts.  cooldude
