February 12, 2026, 12:11:50 AM *
Author Topic: Broken tab on side cover  (Read 977 times)
pocket aces
Tampa, Fl
« on: June 02, 2016, 09:55:42 AM »
The front tab on my right side cover is broken off. I'm sure this happens often. What different things do you do to hold it secure.
« Reply #1 on: June 02, 2016, 10:02:56 AM »
if u have the tab most ABS glue it or plastic weld it. my tab for the left cover went missing so I used Velcro in two places to hold it. been good for a few yrs now.
« Reply #2 on: June 02, 2016, 10:05:52 AM »
There's also some pictures you can search for on the tech board
that show how to glue a romex staple in place of the tab on the
side cover to fix it...
-Mike "side cover staple"
Pete
« Reply #3 on: June 02, 2016, 10:39:26 AM »
Mine were chrome so I just drilled a small hole into the overlap of the front and side cover and used a short stainless screw.
bassman
« Reply #4 on: June 02, 2016, 10:54:34 AM »
Compliments of Ratdog from long ago and far away.....
http://www.vermin-club.org/mods/side_cover_tab_repair.htm
pocket aces
Tampa, Fl
« Reply #5 on: June 02, 2016, 11:20:01 AM »
 cooldude cooldude cooldude  That staple fix looks like the ticket!! Thanks!!!
gregk
Retired
Chippewa Falls, wi.
« Reply #6 on: June 03, 2016, 11:21:05 PM »
I had to redo both mine a long time ago. Took some body's advice of a big paper clip, twisted it and used plastic cement from your local farm an barn store to csment it together. Be sure to ruff up the inside of the cover.
slythern12
Fayetteville Ar.
« Reply #7 on: June 03, 2016, 11:36:38 PM »
Used the best Velcro/Scotch brand velcro I could find..
