February 12, 2026, 01:50:59 AM *
Author Topic: cleaning brake/clutch reservoir  (Read 988 times)
saddlebag
« on: June 04, 2016, 03:28:08 PM »
My sight glass inside the reservoirs need cleaning. Does the metal piece inside pop out?
Any suggestions?
Thanks..........
Participant Southeast Asia War Games
big poppa pump
San Antonio, TX
« Reply #1 on: June 04, 2016, 03:50:39 PM »
No it will not pop out.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
« Reply #2 on: June 04, 2016, 04:15:50 PM »
A Q-tip?
« Last Edit: June 04, 2016, 07:02:38 PM by gordonv » Logged
« Reply #3 on: June 04, 2016, 08:36:02 PM »
A Q-tip?
Spray it with brake cleaner, then use the Q Tip.
saddlebag
« Reply #4 on: June 06, 2016, 07:48:31 AM »
Thanks for the suggestions. Q-tip too big.
I used a pipe cleaner to get between the metal piece and the glass.
Very limited room and access but just kept working at it using clean brake fluid.
« Reply #5 on: June 06, 2016, 09:01:40 AM »
A Q-tip?
But some paper towel in the reservoir first so crud doesn't get down the little hole.
srteach
Twin Falls Idaho
« Reply #6 on: June 18, 2016, 08:29:33 PM »
Brake fluid is hydrophillic (water absorbing / bonding) The crud build up is from water in brake fluid or some other contaminant (obviously) fallout. It happens when the brake fluid cannot absorb any more water \ junk and the junk becomes semi-solid. When you refill with good clean brake fluid, the crud will re-liquify and absorb into the new fluid. Plan on changing the fluid again soon. As you do changes, it will last and look better longer on each change. The cleaner the brake fluid, the better the brake response.
.... Which reminds me ....  Embarrassed ... I need to change mine .....
« Reply #7 on: June 19, 2016, 09:27:28 AM »
+1 me too, for my new to me bike, but then, I bought Dot 3  Sad by mistake, found out when I got home. Now need to buy the Right Stuff.
Now what to do with the Dot 3?
