February 12, 2026, 12:25:17 AM *
Author Topic: Help with I/S Wiring  (Read 1097 times)
GiG
NEAR the "In 'n' Out Burger"
« on: June 05, 2016, 05:31:11 AM »
Looking to hook up a couple low power applications, and wonder where to grab 12V inside the I/S fairing.
Where have you tapped in to 12V?
Is there a convenient place to pick up 12V off one of these connectors?
Don't have the I/S shop manual, can someone identify what these connectors are?
Thanks!
~GiG~
Everything is - Nothing is .
(send it to OSS)
This isn’t Rocket Surgery
da prez
Wilmot Wi
« Reply #1 on: June 05, 2016, 05:56:12 AM »
Gig, the blue wire above #4 should be ignition hot. I looked   at my Clymer and from memory on one cup of coffee. If I am wrong , I will be drawn   and quartered. Check the wiring in tech.
               da.prez
GiG
« Reply #2 on: June 05, 2016, 07:30:50 AM »
Thanks, da prez, I'll start there  cooldude
(send it to OSS)
« Reply #3 on: June 05, 2016, 09:32:46 AM »
CF Sheet 2
14P green, L inner fairing, turn signals switch
9P black, R inner fairing, turn signals
CF Sheet 3
14P green, horn/dimmer
9P black, starter/head lights
What are you looking for, constant power or accessory on?
