February 12, 2026, 12:25:20 AM *
Author Topic: Why No Tube On This T-Connector?  (Read 831 times)
Hard Luck Rodeo
Jonesboro, AR
« on: June 05, 2016, 11:25:22 PM »
I don't think it has ever been connected to anything. Is this possible?
Bone
« Reply #1 on: June 06, 2016, 01:53:05 AM »
Yes
Steel cowboy
Spring Hill, Fl.
« Reply #2 on: June 06, 2016, 03:29:17 AM »
The tee fitting is on the tank vent line in case you drive in water or rain, so as to keep the line open. The other 2 are your carb drain and air filer drain (which should have a plug in it). Look to see if you have any fluid in it and if so drain it.
2001 black interstate
2003 Jupiter Orange wing
big poppa pump
San Antonio, TX
« Reply #3 on: June 06, 2016, 04:21:05 AM »
That's not the vent line tee, it's the tee to the drool tube. It's either disconnected or missing.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Steve K (IA)
Cedar Rapids, Iowa
« Reply #4 on: June 06, 2016, 06:52:01 PM »
You got it.   cooldude
States I Have Ridden In
