February 12, 2026, 12:25:18 AM *
Author Topic: Slow to return to idle.  (Read 1246 times)
fiddle mike
Nothing exceeds like excess.
Corpus Christi, TX
« on: June 06, 2016, 02:14:38 AM »
After my stock '97 warms up, when I snap the throttle, the engine is slow to return to idle.
The carbs were just cleaned and rebuilt (except for jets),  new intake o-rings, vacuum caps and carb boots so, no air leaks.  The bike is de-smogged, so no vacuum lines.
Anyone have any insights or suggestions?
« Reply #1 on: June 06, 2016, 03:00:19 AM »
too lean, idle mixture screws.
Steel cowboy
Spring Hill, Fl.
« Reply #2 on: June 06, 2016, 03:22:01 AM »
First thing I would do is disconnect both throttle cables. Manually move the throttle with your finger and see and hear it it returns by it self to idle position. You could even start it and do it. Then you'll know weather it's the cables or the linkage.
2001 black interstate
2003 Jupiter Orange wing
« Reply #3 on: June 06, 2016, 03:44:51 AM »
I too think there is a throttle cable or linkage issue.
« Reply #4 on: June 06, 2016, 06:26:17 AM »
With the engine NOT running......open the throttle and then just let it go.  It should "snap" shut. If it doesn't, it could be the switch housing.  Its possible to get the throttle sleeve bound by having the housing a tad cockeyed. To correct if that is the problem just loosen the two screws for the switch housing and move the housing around until the throttle snaps shut again.
« Reply #5 on: June 06, 2016, 07:15:22 AM »
Pretty standard malady of carburetors that need synchronizing.
Paladin528
« Reply #6 on: June 06, 2016, 09:15:23 AM »
indication of a blocked slow jet or 2.  mine is currently doing the same thing.  new 35's on order
fiddle mike
Corpus Christi, TX
« Reply #7 on: June 06, 2016, 10:13:33 AM »
My wrench suggested a re-jet, but larger than stock.  I need to confer with him on how that would affect performance.
Paladin528
« Reply #8 on: June 06, 2016, 11:40:20 AM »
It will burn too rich with anything larger than the original 35's.  Stick with what mother Honda made ya
fiddle mike
Corpus Christi, TX
« Reply #9 on: June 06, 2016, 11:53:08 AM »
Thanks for the tip.  The mechanic told me he had to turn the mixture screw way out.   I only know the very basics of carburation.
« Reply #10 on: June 06, 2016, 12:46:01 PM »
now u can know just about everything.
http://www.factorypro.com/tech/carbtun.html    use low rpm
fiddle mike
Corpus Christi, TX
« Reply #11 on: June 06, 2016, 12:48:04 PM »
[/quote]
Thanks!  Knowledge is power.   Wink
« Reply #12 on: June 06, 2016, 05:30:03 PM »
The mixture screws? Are you referring to the pilots? The pilots should be between 1 3/4 to  2 1/4 turns out and even across all the carbs. Ricky- made the suggestion  of carb synchronization which would be important after overhauling your carbs. Cable routing is a possibility.
My rides:
Steve K (IA)
Cedar Rapids, Iowa
« Reply #13 on: June 06, 2016, 06:49:44 PM »
Do you have a stock petcock?  Mine acted like that and come to find out the diaphragm was torn giving me a vacuum leak.
You can check by removing the vac line off #6 that would run to the petcock and see if it will hold vacuum.
States I Have Ridden In
longrider
Vernon, B.C. Canada
« Reply #14 on: June 06, 2016, 07:10:46 PM »
These carbs work well if the m/c is not left to sit for a length of time.  I agree with the others.  Don't fight with it.  Replace the slow speed jets with stock 35's.  set the pilots to 2 1/4 and synchronize the carbs.  Check the petcock for vacuum leak.  Your problems should be gone
warren
fiddle mike
Corpus Christi, TX
« Reply #15 on: June 06, 2016, 09:44:20 PM »
Yes, the pilots.  They are turn out way past 2 1/2.
The guy's  through, so I'm assuming he synched the carbs.
The slow return happened over time, and the throttle snaps back, so I'm doubtful the cable routing is at fault.
fiddle mike
Corpus Christi, TX
« Reply #16 on: June 06, 2016, 09:46:12 PM »
I appreciate all of your inputs.  Thanks.
fiddle mike
Corpus Christi, TX
« Reply #17 on: June 06, 2016, 09:49:18 PM »
warren
The hasn't sat, but it has over 200K without the carbs having been gone through.
When I get up with the mechanic I'll pass along the info.
Thanks.
BonS
Blue Springs, MO
« Reply #18 on: June 07, 2016, 06:06:35 AM »
. . . but it has over 200K without the carbs having been gone through . . .
If you have he carbs rebuilt don't forget to replace the float needles. They're inexpensive and definitely worn out at this age and are a major contributor to hydro lock. All six are just over $20 on Amazon. The floats on the Valk carbs are not adjustable so the only calibration for fuel float height is the proper operation of the float needle. And when the spring inside the float needle gets weak the float tops out on the carburetor body and can't stop the fuel flow.
35's are best on a bike that's ridden often but they're quick to clog when the bike is left sitting. 38's are on the rich side but are much more resistant to clogging.
medulla762
« Reply #19 on: June 08, 2016, 08:33:59 AM »
Had similar symptoms. My issue was the starboard(that will be the right side for all the land lubbers...lol) side enrichment rail was not properly closing. Cleaned and polished the rail and it worked properly.
