February 12, 2026, 12:24:50 AM *
Author Topic: IS Left Handlebar Switch changeout.  (Read 1001 times)
Big Tom 10628
Surprise AZ.
« on: June 08, 2016, 10:04:50 AM »
Has anyone changed the whole switch housing? What do I have to take apart? FSM is worthless and I found nothing in a search.
I lost my turn signal knob yesterday it just popped out and traffic got it..
1999 Valkyrie Interstate
2006 Gold Wing
« Reply #1 on: June 08, 2016, 10:24:41 AM »
I have not.  But in reading the many comments about the chrome switch housing replacements for Honda, it's like there is a gallon of stuff in a half gallon housing.  The disassembly may be a breeze, the reassembly may be a challenge. (which is true for so many things)
Be careful, take pictures, put a tray underneath to catch exploding things.
One thing that can be helpful is to loosen the risers (pad the tank, or dent the tank) so you can slide the bars side to side to make things looser and easier to work on.
Don't know if this is helpful (enough).
http://tech.bareasschoppers.com/handlebars-switches/switch-housing-swap-honda/
Paladin528
« Reply #2 on: June 08, 2016, 10:35:06 AM »
REmove the lever on the side you are removing.
Remove the 2 screws on the bottom of the housing.
On the Throttle side - Disassemble Bike to disconnect Throttle cables (UGH!!!)
on the other side you will need to disconnect the harness down in the bowels of hell
the 2 halves of the switch assembly separate and pull apart.  TAKE A PICTURE OF THE INSIDE OF IT.
There is 10 gallons of crap in a 5 pound bag here
The rest is "straight forward"
Big Tom 10628
Surprise AZ.
« Reply #3 on: June 08, 2016, 10:38:57 AM »
That "Bowels of hell" thing is what I was afraid of.
2006 Gold Wing
Steve K (IA)
Cedar Rapids, Iowa
« Reply #4 on: June 08, 2016, 11:20:27 AM »
You just lost the button?  How about a M/C scrap yard for the button?  Probably other Honda's have the same button.  Or one of the sellers on eBay who part out Valks.  Get the switch housing and pry the button off and JB-Weld it on to your lever that I assume is sticking out?
(just a thought)
States I Have Ridden In
Big Tom 10628
Surprise AZ.
« Reply #5 on: June 08, 2016, 12:01:51 PM »
(just a thought)
I wish it was that easy. There is no lever sticking out.
2006 Gold Wing
Earl43P
Farmington, PA
« Reply #6 on: June 08, 2016, 12:36:05 PM »
BTDT, easy. Buy a new choke cable, it has to be disconnected there anyway. Mine was perilously close to breaking, with 4-5 strands remaining.
All I  touched was the switch housing itself. Once the screws are out, it'll split apart enough for the replacement. I left the lever intact. Frankly, I had the most trouble with the harness clamp straps on the handlebars. Mine is an IS, so the left speaker had to come off. Found a couple spinning inserts there, so expect that.
Overall, it's about a 2 on a 10 scale, with a rear tire change/ spline service being a 7 to me.
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
« Reply #7 on: June 08, 2016, 01:57:43 PM »
It sounds like your turn signal lever broke at the bend. Mine did the same. If so you can just replace that part without removing everything. You have to buy the whole housing to get that part though. I was lucky, a kind member sold me his extra housing dirt cheap.
0leman
Klamath Falls, Or
« Reply #8 on: June 09, 2016, 08:32:23 AM »
what Earl said.  I broke mine off not long after I got HER.  Ended up buying the whole housing.  Wasn't able at that time to find the switch lever.
Big Tom 10628
Surprise AZ.
« Reply #9 on: June 12, 2016, 10:26:55 AM »
Well you were correct..  Sure felt bad taking parts off the brand new left side switch housing but I'm back on the road again..
2006 Gold Wing
« Reply #10 on: June 12, 2016, 02:01:12 PM »
That reminds me. I should probably take mine apart and grease it up . I think that's what did my original in. The grease was pretty dried up.
