February 12, 2026, 12:24:51 AM *
Author Topic: Where is the best place to buy a replacment windshield for a tourer?  (Read 1216 times)
nerider2
Omaha, NE
« on: June 10, 2016, 08:22:34 AM »
I need the replace the shield on my 99 tourer, just the plastic, it is delaminated and pitted.
2014 Daytona Blue Ultra Limited
2000 Stealth Interstate
1999 Excelsior-Henderson
Omaha, NE
VRCC #23874
Iron Butt Association #32532
six2go #152
Ft. Wayne, IN
« Reply #1 on: June 10, 2016, 08:45:53 AM »
www.clearviewshields.com
Quality products,choice of sizes, but they are a small company that makes them as ordered(usually)so you won't get it as soon as some think they should, but worth the wait. They will keep you informed at each step of manufacture so you know where it's at in the process. Sometimes the info is a little late, I was told that mine would ship on a certain day and it was delivered the next day and I'm 2000 miles from them.
Bone
« Reply #2 on: June 10, 2016, 09:33:01 AM »
I bought a Clearview for my 98 Tourer.  Picked 2 inches shorter than stock plus a vent.
I'm 6 ft tall and now look over the shield all the time without stretching. This new size
has given much more turbulence with a big increase in wind noise. My handlebar mounted
speakers became useless above 45 mph. I did install a new larger amp and the music
clarity now is possible at hwy speeds.  Rode 100 miles in a heavy rain (I wear glasses)
visibility was poor I used to tuck in behind the taller stock shield this one doesn't have that
dry area. I still like the shield very much and will buy another if needed.
« Reply #3 on: June 10, 2016, 02:28:22 PM »
There's also Cee Bailey's.
http://www.ceebaileys.com/honda-Valkyrie-GL-1500-C/D-1997-2003-windshield
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #4 on: June 10, 2016, 07:52:40 PM »
I would never ever buy another thin cheap pos  Cleanview. C Baileys is the only way to go
« Last Edit: June 11, 2016, 10:01:28 AM by Attic Rat » Logged
h13man
Indiana NW Central Flatlands
« Reply #5 on: June 10, 2016, 10:00:23 PM »
http://rifle.com/Motorcycle-Windshields-Motorcycle-Fairings-Motorcycle-Parts-Accessories-for-1999-Honda-GL1500CT-Valkyrie-Tourer/B1926.aspx
Hard Luck Rodeo
Jonesboro, AR
« Reply #6 on: June 11, 2016, 12:38:44 AM »
I bought a new Clearview windshield a year ago and am still totally satisfied with it.
« Reply #7 on: June 11, 2016, 02:39:03 AM »
I'm no help! I've bought both Cee Baileys and Clearview Shields and both have been quite serviceable.  Roll Eyes
My rides:
DK
Little Rock
« Reply #8 on: June 11, 2016, 06:51:17 AM »
I'm pleased with Clearview.
I will not order another vented shield. It precludes adding pockets & doesn't pass enough air to be useful, rattles, & dribbles rain.
sdv003
Prescott Valley, AZ
« Reply #9 on: June 11, 2016, 07:38:46 AM »
I'm happy with Clearview as well.  Kept me informed, and I got half off the shield for a defect you couldnt really see.  They offered it, I didnt have to ask.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #10 on: June 11, 2016, 08:54:54 AM »
I have a Clearview on both my Valks and like 'em so far.  The Std has the original spec shield and the I/S has the Xtra Tall with the vent.
States I Have Ridden In
flash2002
Montreal, Que
« Reply #11 on: June 11, 2016, 03:29:40 PM »
They wont deliver to Canada over 21 inch that's stupid, it's only an 1 inch taller.  tickedoff
PharmBoy
Lawton, Ok
« Reply #12 on: June 13, 2016, 05:03:59 AM »
I am a big believer in the Cee Bailey's windshields for a couple of reasons. First, they are a direct copy of the OEM windshield and are thicker and more stable than the OEM.  They give you a lot less wind on your chest because of the circle cut out for the headlight. They are also available in a 2" taller version.  I have one of each on my two '97s.  The taller one is leaned back which gives about the same height.  I might like it just a little better.  I'm sure that it looks better...Jim Smiley
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
Gryphon
Resistance is futile; if less than 1 ohm.
Fulton, MO
« Reply #13 on: June 14, 2016, 07:34:44 AM »
If you haven't found a windshield yet, PM me.  I'm just 2 hours away in Maryville, MO and I've got an OEM windshield in a box in the garage that doesn't have any hardware.  I used the hardware on my Clearview with the vent.  Deer took out the Valk and I didn't retrieve the hardware.  New Valk has a batwing so I still don't need the OEM shield.  I'm willing to be very reasonable on the shield.
