« Reply #1 on: June 13, 2016, 06:53:27 PM » |
Only have the one key ? You didn't leave it in the seat lock did you ? Also don't you get a kink in your neck with your head tilted like that ?
« Reply #2 on: June 13, 2016, 07:03:31 PM » |
Pants pocket of what you were wearing last you had them?
« Reply #3 on: June 13, 2016, 07:15:03 PM » |
Factory (black end) or copy?
If you had a factory key, there is a 3 digit code. With that the lock smith can punch a new key from it. I do this with all my new to me used vehicles, then using that new factory copy, get some copies made to use, keying the new one untouched.
Firefighter
« Reply #4 on: June 13, 2016, 07:59:00 PM » |
If you were getting gas look in the top of the tank cap, you could have left the key there. If you were locking your fork the key could still be in the fork lock so check there. If the engine is running right now I would check the ingition switch cause the key will be there. Hope this helps!
2000 Valkyrie Interstate, Black/Red 2006 Honda Sabre 1100 2013 Honda Spirit 750 2002 Honda Rebel 250 1978 Honda 750
Tfrank59
'98 Tourer
Western Washington
« Reply #5 on: June 13, 2016, 08:34:53 PM » |
is there a hide-a-key in the side cover? probably the ignition key if there is one
-Tom
Keep the rubber side down. USMC '78-'84 '98 Valkyrie, ‘02 VTX 1800, '96 Royal Star, '06 Drifter, '09 Bonneville, '10 KTM 530, '04 XR 650, '76 Bultaco, '81 CR 450, '78 GS 750...
Steel cowboy
Spring Hill, Fl.
« Reply #6 on: June 14, 2016, 03:41:17 AM » |
I know a car dealer can make a key for you with proof of ownership. (BMW $275) Maybe the Honda dealer can make one. URL=http://s1200.photobucket.com/user/2001valkyrie/media/image_zpsh0bjwz80.jpeg.html]  [/URL]
2001 black interstate 2003 Jupiter Orange wing
« Reply #7 on: June 14, 2016, 04:13:50 AM » |
Tucked in a glove?
Now for the stooped question. In the ignition? I know I know I know .
« Reply #8 on: June 14, 2016, 07:00:34 PM » |
Those responses remind me of Blonde Star. If you haven't heard it yet, look it up in youtube.
« Reply #9 on: June 14, 2016, 07:45:38 PM » |
I know a car dealer can make a key for you with proof of ownership. (BMW $275) Maybe the Honda dealer can make one. URL=http://s1200.photobucket.com/user/2001valkyrie/media/image_zpsh0bjwz80.jpeg.html]  [/URL] Yes a Honda dealer can cut you one provided you have the 3 digit code on the lock. I bought a set of saddle bags from an IS to put on the Bee and they had no key so I took the lock out of one of the bags and it had the number on it. I have never had an ignition switch apart but would assume it also would have a code on the side of the tumbler barrel.
RonW
« Reply #10 on: June 14, 2016, 08:42:28 PM » |
The ignition switch should have the key digits stamped on it and that's the most accessible option at this point. The problem was getting the correct size torx bit or torx screwdriver T25 or something to remove the torx screws on the cover. I think it's larger than T25 torx though.
« Last Edit: June 14, 2016, 08:44:14 PM by RonW »
2000 Valkyrie Tourer
