February 12, 2026, 02:07:43 AM *
Author Topic: No start twice today  (Read 1164 times)
SpidyJ
Murrells Inlet
« on: June 21, 2016, 04:57:50 PM »
Once after work today and again after being at home for about 2.5 hrs.
Hit the starter button and it clicks but starter does not turn.
I fiddled withthe gearshift to make sure it's in neutral.  After 8 or ten tries the starter eventually kicks in and it starts.
Has a recent manual rebuilt petcock with no vacuum line and I put a solenoid in to help prevent hydrolock right after I got the bike.
No fuel in the oil.
Just got home and I barely touch the start button and she fires right up.
Need pointers.........I've had the bike 3 years and she has about 38K on her.
Carbs rebuilt after the original owner had hydrolock at 20k.  I bought it right after that with receipts for all the work at the HONDA stealer.
1999 Fast Black Interstate
Peace,
johnnywebb
signart
Crossville, Tennessee
« Reply #1 on: June 21, 2016, 05:03:35 PM »
Research starter button maintenance. Probably just needs cleaning.
« Reply #2 on: June 21, 2016, 05:20:43 PM »
Roger that.        http://www.valkyrieriders.com/shoptalk/VSGPages/starterbutton.htm
A loose battery cable can do the same thing (make you intermittent) (and the sneakiest connection is the negative at the block/ground)
« Reply #3 on: June 21, 2016, 05:27:24 PM »
The 'dreaded CLANK' is the sound of a fuel-lock. A click is a bad or dirty connection.  I agree with the fellas regarding a dirty start switch or a possible loose battery connection or bad ground.[near left foot peg]
« Reply #4 on: June 21, 2016, 06:31:32 PM »
Start your bike where you can see what the head light is doing. It is suppose to turn off when you push the button, and turn right back on after you release it.
The button disconnects the head light circuit, and energizes the starter side.
If the contacts are corroded, or more likely, the grease in with the springs is old, and holding back the springs from pushing the plate to make contact.
They already referred you to the Shop Talk, there is also a lot of search of melted switches too, but poor performance is the most likely issue.
« Reply #5 on: June 21, 2016, 08:14:48 PM »
Reads like a weak battery to me.
SpidyJ
Murrells Inlet
« Reply #6 on: June 22, 2016, 04:58:44 AM »
Well I guess it was more than a click! Fuel dripping from left muffler after start! Took car to work. Dang it....carb needle seat?
Peace,
johnnywebb
Paladin528
« Reply #7 on: June 22, 2016, 05:33:53 AM »
if you can shut it down and start it with no issues after a couple of minutes but not after a couple of hours then your Battery is the likely cause.
Paladin528
« Reply #8 on: June 22, 2016, 05:35:39 AM »
Did it crank without starting?  Fuel in the exhaust means it made it through the cylinder without burning
Ramie
2001 I/S St. Michael MN
« Reply #9 on: June 22, 2016, 06:34:01 AM »
You sure it was fuel and not just moisture?
SpidyJ
Murrells Inlet
« Reply #10 on: June 22, 2016, 09:45:18 AM »
Yeah, I'm sure it was fuel....engine did not turn over before finally starting so there must have been some fuel in one of the cylinders.  Not much came dripped out under the muffler maybe an ounce or two at most?
Pulled the fuse on the DanMarc and let the motor run it out b4 going to work.  Came home, turned gas back on and she started right up......no clicking.
Dumped a bottle of B12 in 3/8 of a tank and went for a 10 mile ride.  She's soaking now with the gas turned off........only what's in the carbs.
We'll see what happens tomorrow morning.  If she starts w/o prollums I'll fill up the tank.
« Last Edit: June 22, 2016, 03:01:26 PM by SpidyJ » Logged
Peace,
johnnywebb
SpidyJ
Murrells Inlet
« Reply #11 on: June 23, 2016, 04:26:42 AM »
The b12 seems to have worked. Didja ever read the ingredients in that stuff?!?  Holy crap!
Peace,
johnnywebb
Paladin528
« Reply #12 on: June 23, 2016, 11:32:54 AM »
You seem to be describing two different problems.  Carb or fuel issues will not cause the starter to "ClicK" or not turn the motor (unless it is hydrolocked).  Clicking is generally caused by a low battery or a bad connection.  These can be intermittent.
Fuel issues present as no start or rough running engine generally.
Fuel is the exhaust is usually a result of flooding the engine.
« Reply #13 on: June 23, 2016, 01:58:56 PM »
Another organic chemist's cocktail for our carbys!  cooldude 2funny Smiley
My rides:
SpidyJ
Murrells Inlet
« Reply #14 on: June 23, 2016, 04:38:35 PM »
I hear ya Paladin, maybe it was a little more than clicking.  I don't know, maybe the  starter was engaging and trying to push out the little bit of gas that had collected in the combustion chamber.
When I saw the gas leaking out the muffler, my mind went immediately to leaky float needles.
Since I did  the B12 treatment it's been fine........time will tell if there is something else going on here.
Peace,
johnnywebb
