February 06, 2026, 02:25:29 AM
Trigger wheel Question
Topic: Trigger wheel Question (Read 1478 times)
TearlessTom
Spanish Fort, AL.
September 24, 2009, 11:18:19 PM »
Since I bought my girl second handed (actually 3rd but not titled) How can I tell if the trigger wheel is OEM, a 4Degree or a 6 Degree?
Tom
Re: Trigger wheel Question
September 25, 2009, 03:52:06 AM »
It says right on the wheel.. It'll be stamped 004 or 006 if its an aftermarket..
TearlessTom
Spanish Fort, AL.
September 25, 2009, 11:36:09 AM »
Thanks. I didnt think it would be that easy.
ricoman
Sarasota, FL
September 25, 2009, 02:05:27 PM »
Yeah, it's easy to read it on the whell.
But, you will need to take a lot apart to get to the wheel.
Read a trigger wheel install post first, then see if you want to go through all that just for a peek.
Imohtep
Helsinki, Finland
November 21, 2012, 11:02:14 PM »
But, if there isn't any text on the wheel>how you know, witch is witch?
http://vrcc.photostash.com/vrcc_32485/MIMG_1492.jpg
Valk with supercharger...that's it!
#32485
MP
North Dakota
November 22, 2012, 05:05:16 AM »
OEM will have none, others will have 004 or 006.
You have to remove the timing belts to get to see the timing wheel though, see above!
MP
"Ridin' with Cycho"
Momz
ABATE, AMA, & MRF rep.
Reply #6 on:
November 22, 2012, 06:03:21 AM »
All aftermarket trigger wheels are a solid stamped piece without any slots or holes. The OEM TW has four slots.
Last Edit: November 26, 2012, 03:06:52 PM by Momz
ALWAYS QUESTION AUTHORITY!
