February 12, 2026, 02:07:38 AM *
Author Topic: Help!! clutch problems  (Read 730 times)
Evie
Naperville, IL
« on: June 28, 2016, 05:39:53 PM »
OK,  Im stranded here in Malta Mt.   Clutch started grinding & had to keep a load on the engine...but it got worse.   Im guessing the problem would be that double clutch plate with the revits.   Need to wait until tomorrow morn to check with a honda dealer in Glaskow Mt...40 mi down the road.   Will have it towed...dont think I should drive it any farther.   Want to tell the guy that this probably the problem.   Hope he has time & parts.   Need to get back to Naperville Il.
Any thoughts or suggestions? ??
« Reply #1 on: June 28, 2016, 06:05:00 PM »
Sounds like you could have a pinion cup issue.  Clutch rivets symptoms usually entail the lever being spongy and the clutch engaging differently than normal.
« Reply #2 on: June 28, 2016, 06:31:03 PM »
+1
Evie
Naperville, IL
« Reply #3 on: June 28, 2016, 07:26:35 PM »
Clutch started  having problems from 4th to 5th and then got worse.   Gears would grind a little when I tried to shift.   It sounds like the rivets  are loose in the clutch basket.   Gets really loud.   I maintain my bike well  and everything is greased.    I pulled my clutch 30k ago and replaced the riveted plate even though I didnt really need it.  Have just spent the past week riding the mtns and pulling a trailer.
« Reply #4 on: June 28, 2016, 07:35:11 PM »
Well it's entirely possible that it's the clutch. But if I was to wager on it at this point I'd think the pinion cup. Or u-joint. Is the clutch lever feeling weird ? How does it act taking off from a stop ?
Evie
Naperville, IL
« Reply #5 on: June 28, 2016, 09:19:54 PM »
Starts off in 1st just fine& 2nds ok but as I build speed  and try to shift it starts the grinding noise, however, when I was riding I had to be speeding up or slowing down to keep a load on the drive shaft or it would make a racket.   Couldnt just coast.  Clutch lever feels ok.
« Reply #6 on: June 28, 2016, 09:29:19 PM »
I think it's ujoint or pinion cup.
Seems to be going around lately.  Shocked
