December 17, 2025, 05:55:48 PM *
Pages: 1 [2]   Go Down
Author Topic: Car Tire  (Read 8188 times)
heavyd
« Reply #40 on: July 22, 2016, 07:08:27 AM »
I got mine mounted at an independent car tire place...his only concern was clearance on the machine and voila done...he will get my car tire business as well...and I am running Toyo Proxes R1R 205/55-16 with 140 AA A
That is a pretty sweet looking tire. Does it work as well as it looks?
Relax
Power & elegance...just like the Valk
Oslo, Norway
« Reply #41 on: July 24, 2016, 12:41:16 AM »
Really cool look, looks also pretty rounded .. cooldude
h13man
Indiana NW Central Flatlands
« Reply #42 on: July 24, 2016, 06:59:59 AM »
As near as can calculate the Austone is a 175/80-16 thus 5mm/.200 narrower & 28mm/1.100 larger dia. (14mm/.550 less clearance under fender) Now it seems I read in the past that there was some inner fender mods to be made? I strongly considering this tire in the future.
The inner fender mods amount to the removal of the nut cages on the sides of the fender.  The Austone
Taxi Tire, being narrow, does not require this mod...
Thank you. I was more concerned about "top" clearance issues but I assume adjusting the preload (presently running #3) will resolve this issue if any. Our Indiana roads really suck but Pence finally let go of the $$$$$$$ to fix our miserable roads with "chip & seal" method.  tickedoff
« Reply #43 on: July 24, 2016, 09:24:50 AM »
As it is taller (akin to a 65), the concern should be the wiring harness under the (center of) the rear fender (rather than the cages).  Mine came a bit loose and got a bit rubbed with just a std 205 60 CT, and that was with 12.5" inch 440 shocks and solo riding.  It was discovered and repaired at a Ujoint change, before I lost any tail lights or shorted.  But that would have happened in time.  I will never know if the wiring got a bit loose on it's own before the rub, or was all caused by tire rub/suspension/big bump.  I repaired, shrink wrapped and tied it all up tighter/stronger than OE and it's never been a problem since.
BoJonJovi
Pueblo, Co
« Reply #44 on: August 02, 2016, 09:37:37 PM »
That is cool. It is cut almost like a MC tire.
Get out there!
falconbrother
« Reply #45 on: August 03, 2016, 10:33:12 AM »
I have the Yokahoma, and I love it. I have about 6-7k on it so far, and just got back from riding the Cabot Trail with it. 3rd time on the trail, first time with a car tire and it handled at least as good as the bike tire did on the pavement and much much better in the loose gravel of construction.
For everyone that doesn't know what the Cabot Trail is, it is like the Canadian East coast version of the Dragon.
Not the crazy amount of corners, but most of the corners are marked for 30km/h and there is frequently a 500+ft cliff on the other side of the guardrail.
I totally want to go up there!!  Stop by and see Pema Chodron while I'm there.
JC
The Beast
Franklin, TN
« Reply #46 on: August 03, 2016, 02:01:32 PM »
I put 25K on a Bridgestone Potenza, which handled well but required a considerable amount of counter-steer. I'm on the Austone Taxi now and I feel like I'm back on a MC tire, and I love it! Larger diameter means a 200rpm drop at highway speed, and sits maybe an inch higher.
Bambam650
Cincinnati, Ohio
« Reply #47 on: January 25, 2019, 11:48:25 AM »
I realize this is a very old thread and this subject has been beaten to death, but I thought I would chime in with some additional information that may help others who are deciding on which car tire they should go with.  My current MC tire is about toast again and I vowed that for the next tire change I would go with a car tire.  I've done a ton of reading on the subject and thanks to threads like this, have narrowed my selection down to five tires.  All of these tires are currently available for the prices I've listed.  They are, in no particular order:
1) Yokohama Avid Envigor:  205/60-16, V rated, Tire Rack - $102 (w/ free shipping)
2) GT Radial Champino VP1, 205/60-16, H rated, Simple Tire - $57 (w/ free shipping)
3) Lufen G Fit AS, 205/60-16, H rated, Tire Rack - $75 (w/ free shipping)
4) Triangle TR978, 195/65-16, H rated, Discount Wheel Warehouse - $52 + $17 shipping
5) Austone Taxi Tire, 175/80-16, speed rating unknown, Simple Tire - $204 (w/ free shipping)
Yeah, the price of the Austone Taxi Tire has really gone up and only appears to be available from Simple Tire.
« Last Edit: January 26, 2019, 06:49:02 AM by Bambam650 » Logged
1997 Standard (Black) original owner, bought new in August 1996
NewValker
VRCC# 36356
Oxford, MA
« Reply #48 on: January 25, 2019, 01:34:58 PM »
ATT is $164.00 at Universal tire.
Craig
Turns out not what or where,
Ken aka Oil Burner
Mendon, MA
« Reply #49 on: January 25, 2019, 03:38:11 PM »
Craig
Universal isn't showing it anymore.  https://www.universaltire.com/175r16-austone-taxi-black.html
Haven't called them to find out what the deal is; whether they're getting more or not.
NewValker
VRCC# 36356
Oxford, MA
« Reply #50 on: January 25, 2019, 04:59:36 PM »
??? Dunno, bought one last month with no problems...
Craig
Jersey
VRCC #37540
Southern Maryland
« Reply #51 on: January 26, 2019, 09:12:44 AM »
I have over 12k on the Envigor ad it looks brand new still.  Also, Amazon has it for $81 shipped if that helps.
https://www.amazon.com/Yokohama-ENVigor-All-Season-Tire-60R16/dp/B004QL6YMW
Just a word of caution on CT's.   DON'T FORGET to still do the routine maintenance on the Drive.  I just did this a few days ago since it's been so long since the last time.  It's easy to just let it go since the CTs can easily give you 30k+ miles.
Jersey
Jersey
« Reply #52 on: January 26, 2019, 09:34:03 AM »
Jersey
Bambam650
Cincinnati, Ohio
« Reply #53 on: January 28, 2019, 06:48:49 AM »
Okay, I just got off the phone with a salesperson at Universal Tire.  They still carry the Austone Taxi Tire and it is still $164.  I didn't ask if that includes shipping or not.  The salesperson said they weren't permitted to advertise it any longer on their website for some reason, but they still have it.
Bambam650
Cincinnati, Ohio
« Reply #54 on: January 31, 2019, 10:07:43 AM »
FWIW, I was searching for the Yokohama Avid Envigor on Amazon and they currently have the 205/60R16 for $73 with free shipping and the 195/55R16 for $62 with free shipping.  Seems like a great deal to me.
Bambam650
Cincinnati, Ohio
« Reply #55 on: February 01, 2019, 05:28:57 AM »
…………….and the winner is:  YOKOHAMA AVID ENVIGOR 205/60R16
I just pulled the trigger on purchasing this tire from Amazon.  After doing a lot of research, I selected this tire for the following reasons:
1)  Great price from Amazon for $73, including free shipping.
2)  Nice aggressive, symmetrical tread pattern.
3)  V speed rating.
4)  Highly recommended by many other Valkyrie riders.
5)  Very good rating in dry, wet, and comfort categories on Tirerack.com.
6)  Quality tire made in the USA; not China junk.
7)  Take a look at the photos from Mallet in post #13.  Need I say any more?
I also strongly considered the Vredestein Sportrac 3 and the Austone Taxi Tire.  However, the Sportrac 3 is an older version of the tire and is very hard to find and I just didn’t think I would like the look of the Austone on the back of my Valk.  Call me shallow I guess.
Now us fans of the Envigor need to band together and persuade Yok to make a 195/65R16 as I think that would be a better fit for our bikes.
« Last Edit: February 01, 2019, 02:06:54 PM by Bambam650 » Logged
RWhitehouse
« Reply #56 on: February 01, 2019, 07:24:03 AM »
Interesting. I noticed that it'd vanished off their site as well, and the "Dunlop Taxi Tire" in the same size shows they're low on stock and supposedly will not be getting more. Searching for "austone taxi tire" only turns it up at one other site, but it's considerably more expensive. It's also gone off their eBay page, but good to know it's still available on request.
« Reply #57 on: February 01, 2019, 10:35:33 AM »
I'm hoping they keep fresh Austones available.  There are many of us who swear by 'em.
nogrey
Nampa, Idaho
« Reply #58 on: February 01, 2019, 11:56:14 AM »
Current most recommended tire is the Austone Taxi tire.
$152
Universal tires
The Austone Taxi is a little more money than some of the other CT’s folks run, but it is such a great tire that I personally think it’s worth it. Love that it lowers RPM’s because it’s taller and it will far outlast a MC tire.
nogrey
Nampa, Idaho
« Reply #59 on: February 01, 2019, 11:58:46 AM »
I had the same problem this time last year. Waited months for one. I was told by the folks at simpletire.com that the manufacturer only does one run a year and when they’re out, they’re out. I got smart on the last one I bought. They had a 20% off plus free shipping in Nov/Dec. I bought one then. If you can wait, I think they do it every year. Did the same thing with my clearview windshield.
« Reply #60 on: February 01, 2019, 12:23:49 PM »
I like my 205s fine.
But if you wanted to stock up, couldn't you buy extra Taxi tires and keep them in your temp controlled house without much usual aging?  You could even hang it on the wall in place of one of those boring wedding photos.   Grin
I always keep an extra ME880 front hanging in my shed, and even a year plus later, it's fine.
« Last Edit: February 01, 2019, 12:28:57 PM by Jess from VA » Logged
Bambam650
Cincinnati, Ohio
« Reply #61 on: February 05, 2019, 07:07:26 AM »
I received my Yokohama CT yesterday.  I'm impressed with how rounded the shoulders are.  Whether it stays like that when it's mounted and inflated remains to be seen.  Don't know when I'll get around to mounting it.  I still have some useful tread left on my MT.
EDIT: I took pics down because Photobucket was letting anyone see my entire photo library if they clicked on the pic.  I need to find a way to fix that.
Okay, figured it out.
« Last Edit: February 05, 2019, 09:01:15 AM by Bambam650 » Logged
Pages: 1 [2]   Go Up
