February 12, 2026, 02:10:21 AM *
Author Topic: *Fixed* Help Radiator Fan not working. Out on trip.  (Read 954 times)
blackcat
Nicholas Vore VRCC # 30301
Mounds, Arkansas
« on: June 28, 2016, 07:15:35 PM »
Hey yall.
Im out on the road at Crossville Tn tonight. Refilled at Mount Juliet tn and keeping a eye on coolant level.
I also am towing a trailer.
Had inner fairing apart for a windshield replacement yesterday.
Took off this afternoon and had a boilover in gridlock traffic at nashville.
Hoping i may have unhooked a wire messing with speaker pods.
Water pump runs. Fan Fuse good.  Fan was working two days ago.
Which side are fan wires in fairing.
All else fails i will hotwire the fan
Nick 870-565-5804
« Last Edit: June 29, 2016, 06:04:23 AM by blackcat » Logged
______________________
03 Standard -Fast Black
00 Interstate - Red/Black
97 Tourstate - Yellow/Ivory
2010 Goldwing - Pearl Yellow
« Reply #1 on: June 28, 2016, 07:25:57 PM »
Take the wire off the temp sending unit, and ground it with the ignition on. That should ground the rad fans, and fire them up.
If that doesn't work, then get back and post.
How did you check the fuse? Swap it out with another known working one, or use a test meter.
signart
Crossville, Tennessee
« Reply #2 on: June 28, 2016, 07:57:48 PM »
I'm here in Crossville, if there is something I can do to help let me know. Just saw this, I could have at least put you up.
blackcat
Mounds, Arkansas
« Reply #3 on: June 28, 2016, 08:31:20 PM »
I landed at the executive on I-40
signart
« Reply #4 on: June 28, 2016, 09:13:42 PM »
Let me know if you need any meters or testers, tools
blackcat
Mounds, Arkansas
« Reply #5 on: June 28, 2016, 09:16:47 PM »
Yea im diggin around no tester and minimal tools, electrical is my weak subject too. Guess pods gatta come off. Ugh
Savago
Brentwood - CA
« Reply #6 on: June 28, 2016, 10:04:06 PM »
This might help you:
https://plus.google.com/+AdenilsonCavalcanti/posts/Vq49QDdrxkG
That being said, I don't think this is a quick job (replacing the fan motor), plus you got to order a new fan motor and that might take a few days.
I was able to run the bike for 2 years with it broken. Basically, if you keep the bike moving it won't over heat.
Plus, *before* overheating, the warning light was supposed to turn on. That is a hint to stop and wait 10-15 minutes for the bike to cool down a bit.
When you make it back home, I recommend getting one of those oil dip stick with a thermometer and maybe install a water temperature gauge? Check:
https://plus.google.com/+AdenilsonCavalcanti/posts/T9tu9rzGNCw
Cheers
Savago
Savago
Brentwood - CA
« Reply #7 on: June 28, 2016, 10:10:01 PM »
And here you can see how to test the fan by grounding the fan:
https://plus.google.com/+AdenilsonCavalcanti/posts/b4sBMSadEv2?pid=6298155140908263202&oid=109764150143106427665
blackcat
Mounds, Arkansas
« Reply #8 on: June 29, 2016, 06:03:18 AM »
Thank for info. Up and going . Wired fan with switch.
falconbrother
« Reply #9 on: June 29, 2016, 10:14:54 AM »
I broke down on a 1977 GL1000 many years ago..fan wasn't working.  I wired in a single throw switch out in walmart parking lot and rode it like that till the day I sold it.
