February 12, 2026, 05:44:45 AM *
Author Topic: HEADLIGHT BULB FOR HONDA VALKYRIE QUESTION  (Read 7985 times)
98 VALK
« on: June 28, 2016, 08:01:13 PM »
Will a 9003 H-4 55/60 watt bulb fit the valk without any cutting or trimming on the bulb prongs. I read an article that said it will work and gives much brighter light. Can anyone confirm this. Don't want to fry any wires. Thanks for any help.
« Reply #1 on: June 28, 2016, 10:32:03 PM »
Yes it will work. I don't think the 55/60 is going to give much more light though. I've got a 90/100 in my standard. But you should probably go with the SmartSwitch so as to not mess up your start switch.
« Reply #2 on: June 29, 2016, 12:56:16 AM »
Ditto on that.  I have run a 130/90 bulb from compacc.com for 18 years with great results.  After doing my headlight relay mod of course.  http://www.horseapple.com/Valkyrie/Tech_Tips/Headlight_Upgrade/headlight_upgrade.html
BonS's Smart Switch is the same thing in an easy to install kit.
« Last Edit: June 29, 2016, 12:57:49 AM by MarkT » Logged
98 VALK
« Reply #3 on: June 29, 2016, 09:53:19 PM »
Thanks for your help guys. I bought a Sylvania ultra blue and it works for me. Way better than the stock one.
« Reply #4 on: June 30, 2016, 11:17:56 AM »
I've seen a couple of posts now, asking the same kind of info, no modification.
H3 is the OEM if I'm correct.
Having the IS, the info is always having to break off 2 of the 3 tabs.
Does this not have to be done on the std/tourer models also.
Roidfingers
Tuscaloosa, Alabama
« Reply #5 on: June 30, 2016, 11:24:02 AM »
plug and play. also did smart switch
« Reply #6 on: June 30, 2016, 11:32:14 AM »
My memory isn't the best, but I think H4 is OEM . The 9003/H4 will go on the standard without breaking tabs.
Roidfingers
Tuscaloosa, Alabama
« Reply #7 on: June 30, 2016, 11:38:26 AM »
Meathead is correct. If our memories are correct.  Grin
98 VALK
« Reply #8 on: June 30, 2016, 10:39:54 PM »
MR. GORDON.  I used the 9003 H-4 55/60 watt Sylvania it was a perfect fit. The prongs were the exact same size as the old bulb. Mine still had the old original bulb in the headlight. Still working after 18 years. The Sylvania is way brighter than the orig. By the way I bought the two pack bulbs at O'rielly auto parts.
« Last Edit: June 30, 2016, 10:42:12 PM by 98 VALK » Logged
« Reply #9 on: July 01, 2016, 10:03:07 AM »
Yes STD/Tourer
I believe you have to trim a tab for the IS
Memor86
Tampico, Mexico
« Reply #10 on: July 02, 2016, 02:22:07 PM »
listen pal, forget about hallogen or xenon bulbs, get a LED bulb and it is the real deal, there are motorcycle kits available that have the proper type of rings so you dont have to modify or cut the bulb for it to fit the honda slot
i just installed a set of those on my interstate and trust me. its the real deal plus it draws less power. something around 30W instad or 55/60
http://www.ebay.com/itm/32W-3000LM-COB-LED-Hi-Lo-Beam-H4-Motorcycle-Headlight-Front-Light-Bulb-Lamp-NEW-/131651361521?hash=item1ea7085af1:g:Yt4AAOSwIwhWRac2&vxp=mtr
Draeger
Nanaimo, British Columbia
« Reply #11 on: July 02, 2016, 03:39:13 PM »
I installed one of these ASAP after getting my Valk 98 Standard. Works incredibly well. You will simply not get a better performing or easier to install lighting upgrade.
http://www.cyclopsadventuresports.com/3800-Lumen-H4-LED-Headlight-bulb-_p_83.html
Had to cut the rubber cap thing that goes over the original bulb, but that wasn't an issue. I've installed the Cyclops bulb on all my bikes. it's the first thing I change when I get a bike.
If you are distressed by anything external, the pain is not due to the thing itself, but to your opinion of it; and this you have the power to revoke at any moment. ~ Marcus Aurelius
Kep
My "Mid-life Crisis "
Indiana
« Reply #12 on: July 03, 2016, 05:42:30 PM »
If you like to see...and be seen...use nothing but Cyclops !
