January 29, 2026, 06:19:53 PM
I/S Seat
Topic: I/S Seat (Read 2334 times)
Mikey
Winona, MN
I/S Seat
September 25, 2009, 09:45:03 AM »
Will an I/S seat fit on my Std? My seat is JUNK, I think the guy before me tried to do the mod to give it the "crotch pocket" and screwed the pooch on it. End result, he took out 50% of the foam, and it's lumpy.
Remember folks, street lights timed for 35 mph are also timed for 70 mph
VRCC# 30782
Joe Hummer
Arnold, MO
Re: I/S Seat
September 25, 2009, 09:58:26 AM »
It will fit but you will have a larger gap between the seat and the tank.
You may also have to change over the rear seat mount from the Std seat to the IS seat and use the top fender bolt to hole the seat in place.
Joe
1999 Valkyrie Interstate
Hellcat
Arlington, VA
Re: I/S Seat
September 25, 2009, 01:52:11 PM »
I happen to have both in the driveway right now, so here you go:
i/s seat on i/s
solo seat on standard
i/s seat on standard (may need rear strap installed to really hold firmly)
i/s seat on standard - gap detail
Last Edit: September 25, 2009, 01:58:21 PM by theopowers
PAVALKER
Pittsburgh, Pa
Re: I/S Seat
September 25, 2009, 09:32:49 PM »
Why not try to get some memory foam and add some padding back in the way you want it? Couldn't be much worse than what it is now right? Or you could always spend a half a grand on some aftermarket seats (and if you do, I recommend Ultimates hands down).
John
Mikey
Winona, MN
Re: I/S Seat
September 28, 2009, 06:29:54 AM »
I've been thinking about doing both, and while I'm at it, I figure I could put a gel pad in the back for The Boss. I want to get them re-covered a different color (tan) anyways. I'll wait till the snow flies to rip into anything tho. Has anyone done a buildup of their seat before?
VRCC# 30782
