February 12, 2026, 03:41:31 AM *
Author Topic: tic  (Read 741 times)
john
tyler texas
« on: July 02, 2016, 04:51:45 PM »
 many thanks ya'll      cooldude
« Last Edit: July 03, 2016, 06:17:32 PM by john » Logged
vrcc # 19002
« Reply #1 on: July 02, 2016, 04:55:26 PM »
First put a meter on your battery. Had the same happen a week ago and had just been running the bike a couple days before,put a meter on it and it read 0.00 tickedoff put the battery out of my other bike in and fired right off. If that isn't the problem check ground and all fuses.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #2 on: July 02, 2016, 06:53:23 PM »
I would check the red connector on top of the starter relay for melting/damage. Check the battery negative connection at the left side of the clutch cover for corrosion.
So many roads, so little time
VRCC # 5258
« Reply #3 on: July 02, 2016, 07:29:02 PM »
Make sure it's not hydrolocked then jump it to your non running car, I bet it starts........battery crapped out
