February 12, 2026, 04:08:03 AM *
Author Topic: Battery screws / Terminal bolts for accessories  (Read 1366 times)
north-aurora
Batavia, IL
« on: July 04, 2016, 07:55:15 AM »
I have been slowly adding accessories and the battery screw and nut is getting too short. I am looking for something that allows me to add accessories that are wired directly to the battery. I now have a hard-wired GPS, air horn, LED lights and USB power, so that's a total of 4 wires to connect to each battery terminal. There has got to be a better way than what I am doing...
I found a terminal bolt that allows for accessories to be connected to the top. But the ones I found seem to be for side mounted batteries, such as this one.... http://www.autozone.com/batteries-starting-and-charging/battery-terminal-bolt/lynx-battery-terminal-bolt/296092_0_0/?checkfit=true
Maybe those do work for motorcycle batteries as well. What do those of you do that have lot of accessories connected to your battery?
« Reply #1 on: July 04, 2016, 08:19:15 AM »
A fuse block. (and relays, when the amount of electrical draw to accessory warrants it)
There's a lot of threads on here about it.
https://www.bing.com/images/search?q=fuse%20block%20on%20motorcycle&qs=n&form=QBIR&pq=fuse%20block%20on%20motorcycle&sc=2-24&sp=-1&sk=
« Reply #2 on: July 04, 2016, 08:48:47 AM »
https://www.amazon.com/gp/product/B00QMTAZ1W/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I used this, with a 40 amp relay conmected to my key switch. Nothing is drawing power until the key is on.
I have my stereo amp, air horns, usb power outlet, and some led lights on it. Works great and now my batter does not go dead after a few days.
« Last Edit: July 04, 2016, 08:52:02 AM by Gavin_Sons » Logged
« Reply #3 on: July 04, 2016, 08:49:33 AM »
Yup, a fuse block and a ground bus, if it isn't already integrated in the fuse block you choose.  See the photos below to see what I did.  The power for the fuse block is taken from the bottom of the 55A fusible link, which is always hot.  In the top photo you can see a heavy red wire behind a thinner red wire; the heavy wire feeds my fuse block under the seat.  The ground bus (with the brass screws) is connected to the frame at the screw that holds the centre cover on.  My battery has not extra connections at the terminals, which sure makes it simpler to pull the battery.
« Reply #4 on: July 04, 2016, 10:43:58 AM »
http://www.easternbeaver.com/Main/Wiring_Kits/Fuseboxes/PC-8/pc-8.html
Triggered by the 5A acc. Wire cooldude
jim@98valkyrie.com
Wayne, PA
« Reply #5 on: July 04, 2016, 06:47:03 PM »
I've got the same thing that Big Head has a link to. It works well and I only have one extra set of wires at the battery. Works and looks really nice.
« Reply #6 on: July 04, 2016, 06:48:11 PM »
Wink can't beat it cooldude
falconbrother
« Reply #7 on: July 04, 2016, 07:13:20 PM »
When I got the Interstate it had LEDs, GPS, etc..  Lots of stuff coming off of the battery and it was a hot mess in there.  I created a sort of redneck bus for both positive and negative sides, since the voltage draw was low.  That cleaned it up and makes it a lots easier to pull the battery if needed.
« Reply #8 on: July 04, 2016, 10:17:35 PM »
It says it's beaver powered; how could you go wrong?.   Smiley
north-aurora
Batavia, IL
« Reply #9 on: July 07, 2016, 08:33:09 PM »
So the ACC wire has only 5A? I have a Stebel airhorn and I think it draws around 16A, so am I better off to connect my fuse block to the bottom screw of the 55A fusibel link? Or maybe wire the fuse block to the battery? I got a 40A relay which I'm planning to put in front of the fuse block.
« Reply #10 on: July 07, 2016, 08:49:33 PM »
The eastern beaver fuse block has a 30 or 50 A ( your choice ) which is wired to the battery but draws no power until the ignition is turned on which triggers the 5a acc wire which is wired to the fuse block and lets the power to the fuse block.
It has 6 triggered fuses and 2 that are hot all the time for such as a clock on you radio.
north-aurora
Batavia, IL
« Reply #11 on: July 08, 2016, 06:19:57 AM »
With your setup you have NO additional wires connected to the battery, but I am wondering if it's better to connect the grounding bus to the frame or to the negative terminal of the battery? Or maybe it makes no difference?
Paladin528
« Reply #12 on: July 08, 2016, 07:37:23 AM »
Always to the frame.  The battery neg terminal is connected directly to the frame anyway.  Why add a possible point of failure to the battery.
On another note there is a spare terminal in the Start relay connector that you can pull 12 V from if you want it clean.
« Reply #13 on: July 08, 2016, 12:33:37 PM »
Yup, from the factory every ground wire leads to a chassis connection, with the battery negative wire going only to the chassis, although I haven't in the last ten years looked precisely to where, whether it be at the engine or transmission.
BobB
« Reply #14 on: July 08, 2016, 07:52:07 PM »
Eastern Beaver PC-8
« Last Edit: May 01, 2018, 08:48:36 AM by BobB » Logged
