February 12, 2026, 02:24:48 PM *
Author Topic: How many miles on austone taxi tire  (Read 2355 times)
mark81
Cincinnati Ohio
« on: July 04, 2016, 10:49:50 AM »
I tried to do a search and it was a bit confusing with people calling that Austone taxi tire  "ATT"  and also a lot of people running the Goodyear assurance triple tread referring to it also as "ATT" or "GOODYEAR ATT"
I am currently running a champiro vp1 205/60/16
https://simpletire.com/gt-radial-p205-60r16-100a1545-tires?stmodel=champiro-vp1&stcategory=all-season&sttype=passenger&gclid=CjwKEAjwkui7BRCf64DNtfDupgoSJAA_0LOomMlHl_hmIJ4ZSiMEbawd4AiETIfwbKpQ0-NrwjNDARoChOnw_wcB
My first car tire and was on the bike when I got it. I am not displeased with the performance or handling of the tire and am not sure of mileage from previous owner but the 8000 miles I've put on it seem to show significant wear. Especially in the center.  Running 38psi haven't fooled around with pressures since it rides good. I am guessing at tire being half worn when I got it so that would estimate 16000 miles on tire. Maybe 4000 left before needs replaced. So 20000 unconfirmed miles on a $55 tire.
I have not heard one bad thing about the taxi tire
https://www.universaltire.com/175r16-austone-taxi-black.html
but at nearly 3 times the cost am I getting 3 times the mileage? 3 times the performance?  There are several people getting 15000 out of a Mc tire. I am willing to sacrifice low speed handling for an extra 5000 miles and over $100 savings with the tire I have now but what would I gain with the austone tire for the additional cost?
1997 Honda Valkyrie
1981 Honda CB750 Custom
« Reply #1 on: July 04, 2016, 11:39:34 AM »
I'm thinking there has been one post from a rider who says he's on his 2nd Austone. Other than that, I don't think many are even on their second yet
Austone Taxi Tire = ATT
Goodyear Assurance Triple Tread = GYTT
Have you serviced or plan on doing it soon, your rear end? Even the CT requires a 10K service. It is usually done when the mc tire is replaced, which is usually around the 10K +/- mark.
« Last Edit: November 28, 2016, 09:05:58 PM by gordonv » Logged
« Reply #2 on: July 04, 2016, 11:54:50 AM »
I'm thinking there has been one post from a rider who says he's on his 2nd Auston. Other than that, I don't think many are even on their second yet
Auston Taxi Tire = ATT
+1,0000000000000000000000000000000000000000000000000000000000000000000000000000000 and then +1 more   Cheesy
« Reply #3 on: July 04, 2016, 12:30:20 PM »
For 55 bucks I would stick with that tire. I might even try it when I replace my yokahama next year.
mark81
Cincinnati Ohio
« Reply #4 on: July 04, 2016, 01:08:42 PM »
Just rolled 50k plugs, air filter and oil change are done waiting on the rain to stop for coolant flush, brake and clutch fluid and final drive service.  Forks aren't leaking so I'll leave that fluid alone.
1997 Honda Valkyrie
« Reply #5 on: July 04, 2016, 01:48:59 PM »
We've got hardcore chip/seal in Western Colorado, chews through tires like heavy grit sandpaper.  I was getting around 8-9k on Avon Cobras.  Got over 18k out of my first Austone, and it was probably good for another thousand.  Have one on both bikes now.  Considering how well it handles, I think it's worth every penny.
« Reply #6 on: July 04, 2016, 05:03:41 PM »
Anyone claiming 15 k on a mc tire I can't believe them unless I ride side by
 Side for all those miles. Can you get 15 k out of a mc tire? Maybe but cords would be showing and only ridin on straight roads. About 9k Max is all I have gotten and yes I do check pressure regular. After about 7 k the handleing changes dramatically.
« Reply #7 on: July 04, 2016, 05:05:50 PM »
Some may be less enthusiastic with the throttle cooldude
« Reply #8 on: July 04, 2016, 05:21:10 PM »
Yeah well maybe but there has never been a mc tire in the back of the Bee for more than 9k MAX.
Sorry I can't believe the 15-20 k on a rear unless I see all miles ridin. Just sayin coolsmiley
« Reply #9 on: July 04, 2016, 05:25:48 PM »
Some may be lighter?
I too don't know how one get a consistent 10k plus on a rear tire.
mark81
Cincinnati Ohio
« Reply #10 on: July 04, 2016, 05:47:19 PM »
On my cb750c I was averaging 6-7k per rear tire and about 8 on front  all you hear are claims of unrealistic mileages on Mc tires and I'm new to the CT so I have no idea what to expect as far as mileage
1997 Honda Valkyrie
« Reply #11 on: July 04, 2016, 06:43:11 PM »
Yeah that's it. They are 98 lbs and get unbelievable milage from the MC tires 2funny don't believe it for a minute  coolsmiley
Had a metzler on the rear of the IS and it lasted about 5k oh it still had tread but if riding other than a straight line it was A turd 2funny
« Last Edit: July 04, 2016, 06:46:04 PM by Bighead » Logged
csj
Peterborough Ontario Canada
« Reply #12 on: July 05, 2016, 03:49:54 AM »
I'm presently looking for a Taxi tire, may not be available here in the great white.
I'm on my second car tire, and both have given me, At Least, 42K miles.
The center is a little worn, and the wear bars are close, but hey. The car tire
is the way to go, if you're trying to save.
Now if I could just find the taxi tire here.
Some comments I've read about the taxi tire are that the low speed handling
problem is much reduced. That would be welcome.
« Reply #13 on: July 05, 2016, 04:29:57 AM »
This ATT has 19,700 trouble free miles on it.
« Reply #14 on: July 05, 2016, 06:50:52 AM »
E3 coming up on 20k miles documented soon to hit wear bars. Latest dyno run on Mustang design type dyno, 106 HP 116 TQ, add 10 to those numbers to compare to a Dynojet dyno.
next rear will be a CT.
ContiGo 130/90-17 rear on front 18k and counting.
DarkSideR
Pueblo, Colorado
« Reply #15 on: July 05, 2016, 08:39:11 AM »
If people would actually post to this website (which is free and easy) we would know total miles on Austones.
http://darkside.nwff.info/?p=tires
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
mark81
Cincinnati Ohio
« Reply #16 on: July 05, 2016, 09:57:10 AM »
thanks for the link  unfortunately not much info and 0 mileage reports for att  that could be a great resource if people would post like you said
1997 Honda Valkyrie
Grumpy
Tampa, Fl
« Reply #17 on: July 05, 2016, 06:15:13 PM »
98 tourer, Austone Taxi tire, 26,000 miles and still have over 50% tread remaining. I will not run any thing else on the rear.
mark81
Cincinnati Ohio
« Reply #18 on: July 05, 2016, 07:24:10 PM »
Are you the same Grumpy from Florida that's on the cb750 forum?
1997 Honda Valkyrie
« Reply #19 on: July 05, 2016, 07:52:19 PM »
I've only been able to find it from Universal, so a mail house in the US and crossing the border to pick it up, or shipping, which will cost too much (their sale is usually free shipping to the Cont US).
I was just going to drop by my local Canadian Tire and look at their winter tires for one with a very rounded profile. Kal-Tire also.
Fazer
« Reply #20 on: July 06, 2016, 07:54:27 AM »
I've got 7,000 on my E3's front and back, and they still look good.  I still have the little titty things from the mold--guess that is more a testament to my riding style than the longevity of the tire.  Running 42 psi in rear and 38 in front.  I lowered the front psi from 40 to see if I could improve the ride--it's really harsh going over deteriorating pavement joints.
I am planning on going to the ATT when I need a new rear, and maybe a MC rear tire on the front, although not totally committed.  There has been some noise about this combo.
Nothing in moderation...
mark81
Cincinnati Ohio
« Reply #21 on: July 06, 2016, 12:14:49 PM »
I put an e3 on the front just before I left for inzane. Pretty happy with it so far as well
1997 Honda Valkyrie
Grumpy
Tampa, Fl
« Reply #22 on: July 06, 2016, 05:09:02 PM »
Yes Grumpy from Florida, but not on the 750 forum.
« Reply #23 on: October 03, 2016, 05:17:27 AM »
Champiro rocks.  cooldude cooldude cooldude
If I get 10,000 miles or a tad more I'll be happy.
mark81
Cincinnati Ohio
« Reply #24 on: October 03, 2016, 02:53:54 PM »
Yes i was quite pleased with it. Replaced with primewell valero touring.  Couple dollars more but was available same day at tires plus with free mounting. I liked the champiro better but not by much. Probably going back to it when this one wears out.
1997 Honda Valkyrie
« Reply #25 on: October 03, 2016, 05:27:37 PM »
This post contains a picture of my ATT @ 19,000 miles, I finally switched it out this spring after putting 33,800 miles on it.  It still had a couple thou left, but I was going on a long trip and wanted to be sure the tire would get me there and back again.
http://www.valkyrieforum.com/bbs/index.php/topic,63892.0.html
« Reply #26 on: October 03, 2016, 05:48:34 PM »
If I could keep from getting flat tires I might get more than 12000 from a Bridgestone 200 series Exedra  Had two flats in that tire before it trashed out in DesMoines
  That was the best handling tire I have had and that includes the toyo proxes I ran before getting my first Cobra and 200 Battleaxe
Running an E3 now cause that is what the shop had at the time but I have an ATT in the basement waiting its turn.  I am optimistic that I will also enjoy that tire on my interstate sometime next year
No secret I am not a canyon carver but I do ride regularly for my sanity  Enjoy following this thread
« Reply #27 on: October 03, 2016, 06:00:28 PM »
I am real pleased with the handling of the ATT, the additional traction, the ride (more cushy than a bike tire even with 43# in it) and dropping the RPM's so I can cruise with Misfit and still get decent mileage.  (Read, Misfit likes to cruise FAST) The fact I can expect at least 20k out of it is just a big bonus.  Not to mention, it's more resistant to road damage than any bike tire, balances just fine with Ride-On (what tire doesn't).  It doesn't really cost less per copy than the online deals on bike tires unless you get it with free shipping.  I didn't.  The handling is much better than all the CT's I tried before it - including GYTT, two different Yoko's, a Vredestein and a Michelin.
« Last Edit: October 03, 2016, 06:02:24 PM by MarkT » Logged
Firefighter
Harlingen, Texas
« Reply #28 on: October 03, 2016, 06:41:31 PM »
I have had two MC rear tires go bad and flat on me, both had around 9000 miles. One went flat while on the road during a rain storm, and I rode it to a stop and the other I heard leaking while parked. Both of these tires were getting close to change time but still were within limits. Both tires just started coming apart in the middle, and looked good when I left home. I check pressure before every ride.
I went darkside not for the price but so I wouldn't feel the need to change tires at 7000 miles because I was wanting to travel far from home. I think the CT carries the heavier load easier and safer. The extra rubber under me gives me confidence while singing along in the middle of nowhere. I have the Yokahama but would like to buy the Taxi tire next time. My reasons.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
JC
The Beast
Franklin, TN
« Reply #29 on: October 04, 2016, 12:05:38 PM »
My ATT has over 12K on it now and still looks new. Rides like a MC tire.
Miker
St. Albert, AB.
« Reply #30 on: October 05, 2016, 07:17:28 PM »
Gordon,
Check out the Continental All Season at CT. I bought one but haven't installed it yet. It has a rounded profile like the Austone.
Hooter
S.W. Michigan
« Reply #31 on: October 08, 2016, 12:10:38 PM »
Old post but, same Grumpy that's been on the Road* forum for years?
