February 12, 2026, 03:41:41 AM
Stuck in gear - ever heard of this ?
Topic: Stuck in gear - ever heard of this ? (Read 1160 times)
Lyle Laun
Calgary, Ab
July 04, 2016, 04:46:06 PM »
I looked at a "cosmetically" damaged Valk today. It didn't look too bad, the owner ran out of road and jammed it between a row of cars and a concrete barrier.
Crash bars & drivers floorboards bent back. No damage to the fenders, mufflers, etc
No visible damage to the gear shift lever but it is stuck in gear. You can push the bike and the driveline turns over the engine.
Anybody ever hear of a Valk getting stuck in gear ? Any idea on how to cure it ?
Lyle
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
signart
Crossville, Tennessee
Re: Stuck in gear - ever heard of this ?
July 04, 2016, 08:06:54 PM »
Yes, not a Valk. Stuck while running? If not try pulling clutch and starting. Also try rocking back and forth (engine off).
Marinakorp
King of Prussia, PA
July 05, 2016, 04:35:09 AM »
Sure its not hydrolocked?
I would rather be judged by 12 than carried by 6
indybobm
Franklin, Indiana VRCC # 5258
July 05, 2016, 06:18:56 AM »
Is the neutral light on? Have you pulled in the clutch lever while trying to move it? How long has it been sitting? It is possible that that the clutch discs are 'stuck' and need to be 'broken loose'. As said before, rocking the bike back and forth with the clutch lever pulled in should it.
So many roads, so little time
VRCC # 5258
Lyle Laun
Calgary, Ab
July 05, 2016, 02:47:37 PM »
No neutral light as it was stuck in gear. I could roll it in gear to confirm it wasn't hydrolocked. The lights came on but not enough juice to turn it over. I didn't think to roll it with the clutch pulled in.
I decided I had enough Valks and didn't take the guy up on his offer, walked away.
Thanks for the input guys !
Get out & Ride !!
bentwrench
Philadelphia,Pa.
July 05, 2016, 04:03:19 PM »
Sounds like the crash may have jammed the shift lever causing damage inside the case.
