January 29, 2026, 06:18:53 PM
Fuel Leak
Topic: Fuel Leak (Read 1690 times)
57cajun
Fuel Leak
September 25, 2009, 09:53:09 PM »
Fired up the big lady tonight, noticed fuel leak(pouring) from upper rear carb area on right bank. Could this be a cracked fuel line or is it from a fuel rail? Any tips are greatly appreciated
Slammer
Lafayette,La.
there are 2 vent lines sticking through the rear brace.....
September 25, 2009, 10:02:30 PM »
if its leaking from one of those it's most likely a stuck float. Just checkin since you have "Cajun"in your handle are you in the Lafayette area???
Dusty
57cajun
Re: Fuel Leak
September 25, 2009, 11:08:48 PM »
Relocated from Lake Charles to Phoenix in mid 90s. I'll check things out tomorrow. Thx for the reply
Slammer
Lafayette,La.
I've rebuilt the carbs on alot of Valks and have had the floats stick-
September 26, 2009, 07:49:20 AM »
after I reinstalled the freshly rebuilt carbs. I had to tap on each bowl until I found the right one and freed the float. If your bike has set for awhile you might need to pull them and clean the bowls & jets.
57cajun
Re: Fuel Leak
September 26, 2009, 11:51:55 AM »
Thx for the help. Stuck float was problem.
