August 09, 2025, 06:00:56 AM *
Author Topic: Valve cover issues (solved)  (Read 1064 times)
larue
Clermont,FL
« on: July 12, 2016, 08:55:12 PM »
Hello everyone , I tried to put new powder coated valve covers, I succeeded on one side but the 2nd valve cover was a challenge, I only manage to get four bolts in and the rest two were impossible . Found out that the threads  on the block where the screws supposed to go is slightly stripped at the enterance making it hard for the pointy head on the screws to catch the healthy part of the thread .
I also and just to check , I put the cover on without the washers on the  screws and they snug just fine. So before going crazy and use a heli coil , any other options or suggestions!
All help is appreciated
« Last Edit: July 13, 2016, 01:45:31 PM by larue » Logged
Thunderbolt
Worthington Springs FL.
« Reply #1 on: July 13, 2016, 11:42:26 AM »
Buy new allen head screws without the pointy ends.  cooldude  Yeah I know they are not just your ordinary screws so maybe do a search on partzilla or some other sites that have searches and see if one of the other models of flat six or 4 cylinder engines had longer screws by a few millimeters and were built the same just longer.  John probably has some in the junk box.
« Last Edit: July 13, 2016, 11:49:07 AM by Thunderbolt » Logged
« Reply #2 on: July 13, 2016, 01:18:28 PM »
As a matter of fact, yes but....they're for the 1200 and are shorter.
TJ
Lake Placid , Fl.
« Reply #3 on: July 13, 2016, 01:34:20 PM »
Pretty sure the wing bolts are a little longer...
larue
Clermont,FL
« Reply #4 on: July 13, 2016, 01:44:54 PM »
You right tj, john also along with few other suggested that, found few here in the garage , everything is good now, and the problem solved. Thanks to all of you
Grumpy
Tampa, Fl
« Reply #5 on: July 13, 2016, 01:57:16 PM »
Yep, gold wings are about 3/8 longer. Goldwing has hydraulic lifters so the covers are deeper.
TJ
Lake Placid , Fl.
« Reply #6 on: July 13, 2016, 02:24:50 PM »
Flrider
Jack
Kissimmee FL
« Reply #7 on: July 13, 2016, 04:14:51 PM »
Larue
Since I am your friend and I don't want to see you go through all that trouble, I'll just take those covers off your hands  Evil Evil Evil crazy2
larue
Clermont,FL
« Reply #8 on: July 14, 2016, 12:14:03 AM »
Larue
[/quote
No more trouble here bud, that's a true friend right there,you can have any of my bikes anytime brother and I mean it
