January 29, 2026, 06:20:09 PM
starting problem
Topic: starting problem (Read 1596 times)
steeldust7
starting problem
September 26, 2009, 09:48:54 AM »
when i turn the key on lights are on, everything normal ,when i hit the starter,somthing trips and no lights or power, let it sit awhile then samething . would this be a battrey or a short causing this?
wildthang1949
Henderson, Tn
Re: starting problem
September 26, 2009, 10:16:12 AM »
Check your battery cables....make sure they are clean and tight......
September 26, 2009, 12:13:29 PM »
Do the starter button mainteance, look in shop talk. hoser
steeldust7
September 26, 2009, 02:15:14 PM »
you were right wildthang, just got time to check it out , ground cable, thanks
