February 12, 2026, 06:17:02 AM *
Author Topic: chirp sound in the front  (Read 1233 times)
« on: July 14, 2016, 04:25:48 PM »
Noticed a chirp or more like a tree frog/ raccoon sound at 15-25 mph. Only hear it a split second. Any ideas? Only changes recently was a new metzler and pads.
Beardo
Regina, Saskatchewan Canada
« Reply #1 on: July 14, 2016, 04:46:28 PM »
I had a similar chirp, I changed the EBC pads to OEM, replaced wheel bearings and remounted the front wheel using the proper tightening sequence. It was good after that.
Sorry, I know that is terrible troubleshooting, changing more than 1 thing at a time, but you might want to try one of those, probably the tightening sequence first, since it's free. Something might be out of alignment.
« Reply #2 on: July 14, 2016, 05:04:35 PM »
Front brakes can chirp, esp if the bike sits a while before a ride.  Stainless steel (rotors) isn't really stainless, more like less stains than carbon steel).
The stains eventually get rubbed off by the pads, but a little steel wool work is quicker.
« Reply #3 on: July 14, 2016, 05:09:29 PM »
she really dont set. I rode it fri sat sun and i think it was fine. I had the radio on didnt notice it.
Michvalk
Remus, Mi
« Reply #4 on: July 14, 2016, 06:11:07 PM »
Well, then, turn the radio back on.........LOL cooldude
DK
Little Rock
« Reply #5 on: July 14, 2016, 07:47:40 PM »
I've about decided you can spend a significant part of your life analyzing strange sounds made by a Valk.
The good thing about it is, give it a few days & it'll be replaced by a different sound from a different place.
« Reply #6 on: July 15, 2016, 04:33:29 PM »
I think I fixed it. It dawned on me that I also put my trigger wheel back on before the tire. Decided to start there and check torque, etc. Tensioner was a tad ft/lb tight. Also noticed the belt had play in it. Tightened it and went around the block. (country block). I didn't hear it or if I did it was very faint. Only thing I heard was my HD horn vibrating under load.  Grin
dalai-lama
Wish I was out riding...
Watertown CT
« Reply #7 on: August 01, 2016, 06:34:03 AM »
If you have not desmogged check the vacuum lines as they sometimes split and make like a reed and can sound like a bird chirping Smiley
the dalai
JOHN R
« Reply #8 on: August 01, 2016, 03:26:55 PM »
 Wink I get that kind of noise all the way here in England, but we don`t have any Raccoon`s only frogs !!!! 2funny 2funny
