March 16, 2026, 03:58:02 AM
Florida Chapter
Emblem Removal
Topic: Emblem Removal (Read 1481 times)
Moofner
Colorado Springs, CO
Emblem Removal
July 23, 2016, 05:50:39 PM »
Hey you crazy Valkats!
I have seen that some of you have the euro badge on your tanks and that some of you have no badge at all!
How did you make this happen? I'd like to remove my Valkyrie Badge to make room for the tribute to the previous owner of my 2003. It is valuable real estate and would be perfect for a decal.
Smother me with your hard earned knowledge.... please?
Also, I'm thinking of another lights project on the 2003. Full LED bulb replacements, rear turn signal/brake module controller, and front LED headlight. Possibly some white accent LEDs to shine off all that chrome. I can't help myself, I need to bling something.
2003 Valkyrie "Ricky's Bike"
2014 Valkyrie "The Gypsy Bride"
Tourus
Spring Hill, fl
Re: Emblem Removal
July 23, 2016, 07:15:26 PM »
I removed emblems by spraying some WD40 and using a piece of dental floss, worked great
Hef
Opdyke, IL 62872
Re: Emblem Removal
July 23, 2016, 07:49:31 PM »
I used a high powered hair dryer and a plastic putty knife, being careful not to scratch the paint. Not too difficult and adds some mystic to the Beast.
Re: Emblem Removal
July 23, 2016, 08:03:00 PM »
When in doubt, go slower.
Re: Emblem Removal
July 23, 2016, 08:17:20 PM »
Some monofilament and a hair dryer. Might also want to wear some gloves since it has a tendency to cut into the flesh. Heat it up with the dryer, then grab the monofilament....maybe 20" and wrap it around your hands a couple times. Slip it in behind the emblem and start working it up and down in a sawing motion while pulling it against the sticky stuff. You'll have to reheat it a couple times but you reach a point where you can pull it off. Once off, there'll be some sticky junk left on the surface. I used GoofOff and wiped it off, then clean it good followed by some polish. Like Jess said....take it slow, and be patient.
Re: Emblem Removal
July 23, 2016, 09:04:23 PM »
I did just as John suggested with some mono fishing line ( heavy - 20 lb test) but I didn't use any heat took about 3 minutes a side
larue
Clermont,FL
Re: Emblem Removal
Reply #6 on:
July 24, 2016, 10:16:43 AM »
What bighead said. No heat needed either when I did mine
