February 12, 2026, 07:41:00 AM *
Author Topic: LED Indicator light replacements  (Read 1012 times)
Harryc
Sebastian, Fl
« on: July 23, 2016, 08:15:06 PM »
I have a '97 Valk Tourer and one thing that I've noticed is the neutral light is dim in bright daylight. I am guessing there is an LED replacement for the indicator lights. Does anyone have the part number and source? I have used superbriteleds.com in the past and like them. Just need some guidance on what to order for the Valkyrie.
h13man
Indiana NW Central Flatlands
« Reply #1 on: July 24, 2016, 05:39:31 AM »
Well I see you made it.  Grin https://www.superbrightleds.com/moreinfo/instrument-cluster-gauge/194-led-bulb-5-led-miniature-wedge-retrofit-car/199/ I put these in this winter in white. They were a bit snug going in. Greatly improved night time visibility. Welcome to community.
Harryc
Sebastian, Fl
« Reply #2 on: July 24, 2016, 07:32:37 AM »
Hey, hey hey look who's here  cooldude .... seems we're destined to spend some forum time together. Thanks for the tip!. I'll order (3) of the 194 LED Bulb - 5 LED - Miniature Wedge Retrofit - Natural White
Roidfingers
Tuscaloosa, Alabama
« Reply #3 on: July 24, 2016, 08:33:18 AM »
Harry, double check the small wires at bottom of tube to be sure they are aligned properly. I installed one and had to remove and realign the wire then worked good. Check everything before reassembly.
Harryc
Sebastian, Fl
« Reply #4 on: July 24, 2016, 08:37:15 AM »
@Roidfingers , I think what you are saying is polarity matters when installing the LEDs. Thanks.
Roidfingers
Tuscaloosa, Alabama
« Reply #5 on: July 24, 2016, 08:45:45 AM »
More that the wires can be bent over to the side and not make contact when installed. You will see when you get them.
Harryc
Sebastian, Fl
« Reply #6 on: July 24, 2016, 01:01:09 PM »
Ramie
2001 I/S St. Michael MN
« Reply #7 on: July 25, 2016, 08:18:37 AM »
Good to see you here Harry, how do you like the Valk so far?
Harryc
Sebastian, Fl
« Reply #8 on: July 25, 2016, 11:23:03 AM »
Hey Ramie..thanks!. I'm loving the fat lady so far...awesome bike. Power, handling, it's all there, and talk about a bike designed for touring...wow.
