February 12, 2026, 06:15:43 AM *
Author Topic: 1999 interstate new to me  (Read 1228 times)
tx blue
« on: July 24, 2016, 12:13:05 PM »
Just picked a 1999 interstate with 31,000 miles don't know bikes history would like to go through it where should I start on things of importance.
Phil
« Reply #1 on: July 24, 2016, 01:07:13 PM »
Rear end. Not much more than that if it is running well.
Roidfingers
Tuscaloosa, Alabama
« Reply #2 on: July 24, 2016, 01:31:58 PM »
And all the fluids.ie: brake/clutch, engine oil, coolant and rearend oil when you pull ,check, and regrease.
« Reply #3 on: July 24, 2016, 01:35:00 PM »
Click on the Texas board and ask for help/info from some local help. When you change the rear tire, pull the drive unit and check splines and drive shaft. Get the latest info on spline grease and shaft grease. The bolt tightening sequence of the drive unit is important so ask when you get around to it.
Roidfingers
Tuscaloosa, Alabama
« Reply #4 on: July 24, 2016, 02:04:48 PM »
Check the shop talk articles. So much great info. Have a write up with pics for rear end by ChrisJ.
« Reply #5 on: July 24, 2016, 02:44:24 PM »
Fluids to me would be a given on any vehicle.
« Reply #6 on: July 24, 2016, 03:53:25 PM »
Comin up n 122000+ on my 99 I/S. That equates to 87000 miles I put on her since I bought her. That rear end maint I M H O is THE single most important aspect of the long lives these machines can achieve. A GOOD synthetic or dino oil is the next. And in my case anywho-good clean electrical contacts. Take awhile and peruse the tech archives here. LOTSA cursed good info on our rides of choice. And consider yer self warned-all those miles and all these years later-she STIL makes me grin!  cooldude Welcome to our sand box and the insanity-RIDE SAFE.
Mr.BubblesVRCCDS0008
« Reply #7 on: July 24, 2016, 04:02:16 PM »
Where abouts in Texas. Large area to cover. I'm northern side of Houston. Glad to help.
tx blue
« Reply #8 on: July 24, 2016, 05:47:57 PM »
Austin tx any help appreciated on rear end wk.
Phil
« Reply #9 on: July 24, 2016, 09:18:58 PM »
Get a Honda manual or a Clymer manual for your Valkyrie. Lotsa information on the board you an print and create your own loose leaf binder setup. As many times as I've done the rear end service I still follow the procedure(s) laid out in the service manual. if you know which end of a screwdriver or a wrench to hang onto you can do your own service.  cooldude RIDE SAFE.
falconbrother
« Reply #10 on: July 25, 2016, 08:37:19 AM »
I also have a 99 IS.  Love it.  Best bike of my life so far.
« Reply #11 on: July 25, 2016, 08:48:52 PM »
Try going to Texas board. A lot of good people in the Austin and San Antonio area. Welcome to the family.
ShiftHappens
South Suburbs Chicago, IL
« Reply #12 on: July 27, 2016, 09:31:29 AM »
I concur with changing all fluids.
I would also recommend shock bushings on tire change as well as an air filter. Other items on an as needed basis. Intake o-rings were an issue for me (I used Red-eye parts). I do ride with a spare kickstand spring and bolt just in case.
I would also highly recommend Jake Wilson tire valves! https://www.jakewilson.com/p/1753/19082/Myers-90%C2%B0-Tubeless-Chrome-Valve-Stem
I bought my Interstate almost 5 years ago and have put on about 40,000 miles.
I did go Darkside (car tire) and like it.
Download service manual:  http://www.valkyrienorway.com/download.html
Maintenance guide: http://www.rattlebars.com/valkfaq/valkmaintenanceguide.html
Generic part equivalants: http://www.jkozloski.com/generic_parts.htm
There is lots of help available on this board and past issues via searching past board discussions.
Here is original brochure I scanned. Click on picture to download. Its 11 x 38 inches double sided so the file size is ginormous.
« Last Edit: November 23, 2019, 05:52:53 PM by ShiftHappens » Logged
1999 Interstate
