February 12, 2026, 06:16:42 AM *
Author Topic: Plug and play L E D lights  (Read 1342 times)
« on: July 24, 2016, 03:42:38 PM »
Has anyone here found a true plug and play L E D tail light turn indicator replacement bulbs that are TRULY plug and play? No resistors etc etc. AND if yes-bulb name(s)/numbers and supplier(s) please. Yup-wanna make my Phatt Ghurls butt easier to see!  Roll Eyes T I A for any and all help.  cooldude RIDE SAFE.
« Reply #1 on: July 24, 2016, 03:50:19 PM »
the flasher has to be changed to an LED flasher, for plug and play.
« Reply #2 on: July 24, 2016, 09:01:09 PM »
Did some lookin around and on the superbrightleds they seem to have everything I need. I'll make sure of a parts list 2moro or the next day. Added bonus-they are located in St. Louis mo. RIDE SAFE
« Reply #3 on: July 25, 2016, 03:37:44 AM »
http://www.customled.com/products/elfr-1-electronic-led-flasher-relay
There is the flasher [ thanks to Bagger John].
Any auto store now has  1157 LED replacement lights.
Wayn-O
Orem, UT
« Reply #4 on: July 29, 2016, 01:27:09 PM »
I would also be interested to know what 1157 LED you guys would recommend for the tail light.  I read on rattlebars faq page in shop talk that they are not that good.  It's at the very bottom of his write up, with this link:
http://www.rattlebars.com/valkfaq/ledbrake.jpg
Although, if you guys know of a good one to use that doesn't suck and has good running/braking brightness change that'd be sweet. Some I've read are bright, but when you apply the brake they are still bright, so it's hard to tell when you are actually braking...
There are so many to choose from on Amazon, I don't want to waste time and money with the wrong choice.
Thanks.
2000 GL1500C Valkyrie
2003 VT1100C Shadow Spirit
1998 VT1100C Shadow Spirit
1983 VF750C V45 Magna
big poppa pump
San Antonio, TX
« Reply #5 on: July 29, 2016, 01:40:37 PM »
Have this on both my bikes.
https://www.amazon.com/Radiantz-Tail-Light-Honda-Shadow-Valkyrie-VTX/dp/B000TK8LY8/ref=sr_1_1?ie=UTF8&qid=1469825508&sr=8-1&keywords=radiantz+valkyrie
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
« Reply #6 on: July 29, 2016, 01:45:51 PM »
get the highest watt ones, big poppa pump give listing for 50watt true signal bulbs, they work great even in direct sunlight. remember to get same color led as your lense.
http://www.ebay.com/usr/dt-autotech?_trksid=p2055119.m1438.l2754
« Reply #7 on: July 30, 2016, 03:43:42 AM »
I installed [ after being rear ended] an LED panel light [ I think from Radianz]  with puck lights in the saddle bags for tail and stop lights. The turns were from an auto parts store and all seems to work fine. They are bright.
Crackerborn
SE Wisconsin
« Reply #8 on: July 30, 2016, 05:41:46 AM »
A diode must be added to one line of the turn signal indicator to convert to LED turn signals. One more thing to put in the headlight bucket where there is just so much room to work on the standard and tourer. The interstate, if it has a single indicator to tell you either turn signal is working, it will also need a diode. Someone mentioned a unit that will solve the issue some time back, I think a Kassin(sp) Signal Minder, but I have not tried one yet.
97 Valkyrie Tour
99 Valkyrie Interstate
« Reply #9 on: July 30, 2016, 01:33:48 PM »
I installed a LED turn signal relay.
