February 12, 2026, 06:15:45 AM *
Author Topic: Low beams work, high beams don`t 2000 Interstate  (Read 825 times)
Motorider
Pennsylvania
« on: July 28, 2016, 12:33:02 PM »
2000 Interstate. Everything is stock. The high, low, switch checks out OK. All plugs seem to be clean and making contact. Would a bad relay cause this? If so, I need a part number for the relay. My shop manual shows a relay but no part number.
h13man
Indiana NW Central Flatlands
« Reply #1 on: July 28, 2016, 12:41:14 PM »
Bulbs can go bad even though you can still see "good" filaments inside the bulb.
Motorider
Pennsylvania
« Reply #2 on: July 28, 2016, 12:44:51 PM »
Should have mentioned that the bulbs were both replaced last summer. Also they both stopped working at the same time, I am sure it is an electrical problem.
Motorider
Pennsylvania
« Reply #3 on: July 28, 2016, 01:29:01 PM »
I just discovered there is another relay, with the same part number in the harness. I swapped the relays and still no high beams.
Motorider
Pennsylvania
« Reply #4 on: July 28, 2016, 01:42:34 PM »
Just made another discovery!!! There is a low beams relay AND a high beams relay. I swapped them and now I have high beams and no low beams. Eureka
h13man
« Reply #5 on: July 28, 2016, 02:57:04 PM »
I think you got it. I'd swap both of them out for new ones and have a spare.
Motorider
Pennsylvania
« Reply #6 on: July 28, 2016, 03:50:16 PM »
Great minds think alike! I have two on order.
« Reply #7 on: July 28, 2016, 04:53:47 PM »
Are these relays behind the coolant reservoir ?
« Reply #8 on: July 28, 2016, 05:09:13 PM »
Yup, in front of the battery.  There's 5 there, 4 the same and the other is the turn signal relay.  The 4 that are the same are 1 low beam, 2 high beam, 3 bank angle and 4 radio.
