February 12, 2026, 07:40:34 AM
Drive Line
Topic: Drive Line (Read 746 times)
Bronxboy
Tampa Bay FL
Drive Line
August 01, 2016, 12:35:17 PM »
Will a Drive Line from a Interstate fit the Tourer?
https://photos.app.goo.gl/Z8XVCYBWHGEvRSvL2
Re: Drive Line
August 01, 2016, 01:30:06 PM »
Yep. Perfectly.
Re: Drive Line
August 01, 2016, 01:32:16 PM »
My definition of a drive line would be everything aft of the engine to the rubber of the wheel.
Yes, they are all the same, for the std/T/IS (rim/rotors need to match).
Even the GW rear swing arm will fit on a Valkyrie frame, thereby converting your rear drive/rim to a cheaper easier to get GW model.
Re: Drive Line
August 01, 2016, 01:43:37 PM »
There is one small possible exception. I was told when I called Honda to find out why '97 drive shafts cost almost twice as much as all the rest. They told me the '97 was smaller diameter near the output shaft and the later year shaft may rub on the inside of the swing arm if installed on a '97.
So since there were no Interstates for model year '97, theoretically if you put an IS drive train on a '97 standard or tourer, the drive shaft is the only possible issue. If the standard or tourer is a 98 or newer, no issue.
Bronxboy
Tampa Bay FL
Re: Drive Line
August 01, 2016, 02:09:43 PM »
Mine is a 98 Tourer, Thanks All
