February 12, 2026, 11:51:56 AM *
Author Topic: Neutral and Turn Bulbs for Headlight Bucket  (Read 2387 times)
Jruby38
Oxford Mass.
« on: August 01, 2016, 02:54:13 PM »
 I read a post last week about LED 194 bulbs for neutral that show up better in bright sun.  I the 194 size does not fit. Does anyone know the correct size in LED or brighter regular bulb?
Harryc
Sebastian, Fl
« Reply #1 on: August 01, 2016, 05:35:06 PM »
These don't fit? I was told they might be tight ... https://www.superbrightleds.com/moreinfo/instrument-cluster-gauge/194-led-bulb-5-led-miniature-wedge-retrofit-car/199/
h13man
Indiana NW Central Flatlands
« Reply #2 on: August 01, 2016, 05:53:43 PM »
Yep their a little snug but went in. Might try the wiggle technique.  Wink
Went and measured the bulb and the max. OD is about 33/64" (15mm/.515). One could carefully ream the opening by hand with 33/64" drill or reamer which wouldn't effect the  mounting whatsoever.
« Last Edit: August 01, 2016, 06:11:26 PM by h13man » Logged
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #3 on: August 01, 2016, 08:14:17 PM »
They fit, it's just a tight fit; I'm running them in my standard.  Oh, and they're worth the trouble in my opinion.
h13man
« Reply #4 on: August 02, 2016, 06:50:24 AM »
Why would they need to work in the bright sun anyway ????
Jruby38
Oxford Mass.
« Reply #5 on: August 02, 2016, 01:35:07 PM »
I don't see how a 194 led will fit in the rubber socket. My bulb matched to a number 34 and NAPA said that size is not make in led. I also installed 1174 LED's in front turn/running lights. They work but flash much faster than stock, like a strobe light.
Harryc
Sebastian, Fl
« Reply #6 on: September 09, 2016, 01:20:56 PM »
I got the LEDs recommended here and the wedge/base is at least twice the size of the socket in the bike. I don't get it. I have a '97 tourer.  Honda parts says it takes a T6.5 wedge, 12v 3W. Part number 34908-KM1-671. I wonder if something like this would work - https://www.ledlight.com/t6.5-wedge-1-led-round-12-volt.aspx
« Last Edit: September 09, 2016, 01:38:24 PM by Harryc » Logged
Jruby38
Oxford Mass.
« Reply #7 on: September 09, 2016, 01:40:07 PM »
NFW that 194 led bulb will fit in the socket without some Micky Mouse.
Harryc
Sebastian, Fl
« Reply #8 on: September 09, 2016, 02:09:09 PM »
Here's a pic of the stock t6.5 bulb on the left and the 194 LED on the right ....
« Last Edit: September 09, 2016, 03:12:08 PM by Harryc » Logged
Harryc
Sebastian, Fl
« Reply #9 on: September 09, 2016, 04:40:54 PM »
Well, I ordered these. I know they will fit...but brightness is the issue. We'll see.
If those are too dim I'll try these next ...
http://www.ebay.com/itm/2pcs-24-T6-5-Instrument-Panel-3-LED-Bulbs-Blue-White-/201656672360?hash=item2ef3aca068:g:SSIAAOSwMNxXaeow&vxp=mtr
@Jruby38 , if you want to try the EBay ones we can compare notes. I think we're on the right track though.
« Last Edit: September 09, 2016, 04:54:29 PM by Harryc » Logged
mark81
Cincinnati Ohio
« Reply #10 on: September 10, 2016, 03:30:02 PM »
I have 194 bulbs in my valk gauges
do you have an interstate? they have different gauges and possibly use different bulbs
1997 Honda Valkyrie
1981 Honda CB750 Custom
Harryc
Sebastian, Fl
« Reply #11 on: September 10, 2016, 03:49:07 PM »
Nope. I have a '97 Tourer. There is something about these bulb/LED indicator parts that is different by year or model that I haven't figured out yet, but I will. Wink You did see the pic I posted eariier right?
« Last Edit: September 10, 2016, 04:34:22 PM by Harryc » Logged
mark81
Cincinnati Ohio
« Reply #12 on: September 10, 2016, 03:49:49 PM »
disregard above post. the gauge lights are 194 bulbs not sure about indicator lights. I think others have made the same mistake and that may be what has lead to the confusion of bulbs
1997 Honda Valkyrie
mark81
Cincinnati Ohio
« Reply #13 on: September 10, 2016, 03:53:55 PM »
this is what I changed not the indicator lights in the headlight.
1997 Honda Valkyrie
Harryc
Sebastian, Fl
« Reply #14 on: September 10, 2016, 04:02:08 PM »
You could be right. The Ops intent (and mine too) was to replace the indicator bulbs in the headlight bucket. I wouldn't normally call the tach and speedo (or guage) bulbs/LEDs indicator lights...maybe backlights? Turn signal indicator, neutral indicator, high beam indicator. Wink They are tiny bulbs in a standard and tourer. The 194's  are massive in comparison. The good news is now that I know what is being talked about with regard to the 194's, I now have a use for the (2) of them that I thought were trash....new tach and speedo backlights.
« Last Edit: September 10, 2016, 04:10:50 PM by Harryc » Logged
mark81
Cincinnati Ohio
« Reply #15 on: September 10, 2016, 05:04:14 PM »
I recall a post about the turn signal indicator must be incandescent due to polarity sensitivity of led bulbs and there is only 1 indicator for both directions. something about a harness from a rebel250 fixing this comes to mind also.
1997 Honda Valkyrie
Harryc
Sebastian, Fl
« Reply #16 on: September 10, 2016, 05:11:39 PM »
That is misinformation as well. You can run an (headlight bucket) LED indicator for turn signals no problem. The issue comes into play when you start putting LED turn signals or a digital Signalminder or flasher on the bike, then you need to run a diode kit (or a home brewed diode setup with radio shack diodes) on the turn signal indicator circuit. Below is a good thread on the subject. I plan to do three things. Replace the turn signal indicator with an LED, install a Signalminder,  'and' install a diode kit.  A fourth but cosmetic to-do is to tint the inside of the rear amber lenses to red using transparent red testors model paint...candy red. All of this information I got from helpful folks and thread research at this site. Sometime down the road I will replace all of the turn signal (and every other) lights with LEDs. It will be plug any play then because I'd have done these prerequisite steps. The preceding information applies to Valk Standards and Tourers only. I have not done any research on Interstates.
http://www.valkyrieforum.com/bbs/index.php?topic=9264.0
« Last Edit: September 10, 2016, 05:32:42 PM by Harryc » Logged
h13man
« Reply #17 on: September 12, 2016, 06:46:36 AM »
As Harry C has mentioned diodes have to used in the turn signal circuit even using a piezo buzzer in the circuit. Sorry Harry on the confusion of the bulb location/use. I just got done ordering the Superbright T74 warm and natural whites. They have the same specs as the 6.5's.
Harryc
Sebastian, Fl
« Reply #18 on: September 12, 2016, 08:08:20 AM »
@h13man, no problem I appreciate the help. As I said before it's all good because now I have LEDs for the Speedo and Tac on hand, which were going to be replaced anyway.
Harryc
Sebastian, Fl
« Reply #19 on: September 14, 2016, 02:22:19 PM »
So I installed these LEDs in the headlight bucket- https://www.ledlight.com/t6.5-wedge-1-led-round-12-volt.aspx
I also installed a home brewed diode kit using Radio Shack diodes. The result is good. The LEDs are much brighter than stock and the diodes are doing their job. Next step is to install the Kisan SignalMinder. Just to have on hand, I also ordered those Ebay LEDs. Slow boat from China, but I'll try them as well when they arrive.
Gangman036
Terre Haute, IN
« Reply #20 on: September 18, 2016, 11:50:23 AM »
I just put in the 194 B SuperBright SYLVANIA bulb in "BLUE". I'm super stoked and waiting to see how it looks at night.
Remember...1 very small screw in the mileage reset knob and my 03 has a screw on the back side of the speedo housing, close to the headlight housing not the bottom of the speedometer. Speedo housing came right off. Pull (gently) on the rubber light housing and install the new bulb.....nothing. Pulled bulb out spun it 180 and put it back in.....we got light !! Thanks for all the post on this "dim gauge lighting" fix.
                                                       Ride Safe !!!
