March 12, 2026, 11:43:47 AM *
Author Topic: Well I got the Valk apart today.....Thanks Don. You were completely correct.  (Read 1751 times)
2tonevalk
Whazzup????
« on: September 27, 2009, 03:39:24 PM »
The splines on the driveshaft and pinion cup were dry as a bone.  The rust just ate up the splines.  I found quite a lot of powdered rust.  So I learned a valuable lesson.
Thanks Don for the help.  I am replacing everything from the engine shaft back.  I will keep in mind what you said about removing the pumpkin and greasing the splines when I do tire changes.
Thanks again for everyone's help.  Will see you on the road again very soon.
Ride safe
thumper
« Reply #1 on: September 27, 2009, 05:19:02 PM »
If you buy tires is it the responsibity of the company doing the job to do this?  Is that understood or do I need to insist on it?
« Reply #2 on: September 27, 2009, 05:30:33 PM »
I'd bet the river bottom farm unless you're standing there watching them this does not get done. Buy a jack and do-it-yourself that way you know it's getting done.
2tonevalk
Whazzup????
« Reply #3 on: September 27, 2009, 06:18:28 PM »
Yep Joe,
That is exactly why I did that same thing.  Like You,Don and JP said, the rearend is supposed to "auto" oil this thru the 2 holes in the bottom of the spline cup.  However in reality, as mine was, this feature does not work on most bikes.   Mine was bone dry.
I wish I had known about this earlier.  However I have 70,000 miles so I cannot complain either.  But rest assured, I WILL be doing this as part of my tire change from now own.
So hopefully I will have it back to gether and going in a couple days.  Just in time for the Fall Color Ride.
And Thumper, if you are gettin it done by the shop, I am sure they will tell you that this item is self oiling and this is not required.
Ride Safe
Highbinder
Bastian/Tazewell,VA.
« Reply #4 on: September 27, 2009, 06:46:23 PM »
Glad to be of help Robert....I've seen to many dealer serviced bikes that don't get lubed at tire changes....now a days these young mechanic's don't service many valks...I've had them leave the thrust washer out...had this happen out in Washington state when I had to purchase a tire on the road and they would not allow me in the back Undecided I'm a believer in that if you're going to ride a bike that is not in production any longer, you had better learn to maintain it yourself...buy the service manuel and just do what it says cooldude
Detn8er
« Reply #5 on: September 27, 2009, 07:11:38 PM »
The first time I had new tires put on I took my wheels off and took them to the local dealer. I asked the service manager what type grease they used when they did it them selves. His reply to me was "We don't lube them, I've never known anybody to have a problem with rear splines." That was enough to convince me to NEVER allow anyone but me to change out my wheels. I know each time everything is done right and all items are lubed and I think very importantly TORQUED to the proper specs.
« Reply #6 on: September 27, 2009, 07:27:59 PM »
I guess the passageways had clogged up. I recently took the pinion cup out of the final drive
that was on my bike when I got it and cleaned it up to see if it seemed good (it does seem good)
and I blew the obstructions out of the passageways... wasn't thinking about it at the time, but
I can't think of a good way to routinely clean them out with the pinion cup installed...
MP
North Dakota
« Reply #7 on: September 28, 2009, 05:04:07 AM »
Clean the holes out at service time.  Only use an assembly amount of reg grease on the splines.  If you use a lot of grease, you WILL plug up the holes.
MP
"Ridin' with Cycho"
2tonevalk
Whazzup????
« Reply #8 on: September 28, 2009, 02:30:27 PM »
Just got everything ordered.  I ordered new yoke, drive shaft, boot (noticed a hole), and the pinion cup.  I am right to assume I can use the same springs, washers, and oil seal from the original drive shaft?
Thanks again.
Detn8er
« Reply #9 on: September 28, 2009, 02:52:00 PM »
I don't think I would use the same dust seal Robert. I think the spring washer and locks are OK.
If I remember correctly the dust seal is only a couple of bucks.....The reason I wouldn't use the same one is for looseness(is that a word?) I  took my rear drive off once to find the seal was loose and had worked it's way up the shaft....not pretty.   Cry
2tonevalk
Whazzup????
« Reply #10 on: September 29, 2009, 03:58:02 PM »
Thanks Det,
I called HDL this morning and added it to my order along with a couple other things...just to have available.
Anyway, hope I get them in and put on so I can ride it around her to make sure its fixed before heading to Robbinsville.  I dont really wanna do the "Stanley Steamer" thing.  LOL
Ride safe
Stanley Steamer
Athens, GA
« Reply #11 on: September 29, 2009, 04:16:39 PM »
Thanks Det,
Ride safe
I'll swing by and pick you up in the Kia machine.....OR, you can ride bitch on the big green machine!!.......naw, I don't have the HD shocks for that ya old fart!!..... Cheesy
Stanley "Steamer"
"Ride Hard or Stay Home"
