February 12, 2026, 07:41:02 AM *
Author Topic: Flasher Location  (Read 5424 times)
Jruby38
Oxford Mass.
« on: August 10, 2016, 06:53:01 AM »
Hi. Anyone know the location of the flasher on a 99 standard?  I want to change to an electronic one for LED turn bulbs. Looked under right side cover by fuse box but don't see it.
Thanks.
« Reply #1 on: August 10, 2016, 08:07:47 AM »
#12 in this diagram, located in front of the battery.  They call it a turn signal relay, and it's $42, so I suspect it's more than just a simple flasher, but others can clarify.  I've never had to mess with it.
« Reply #2 on: August 10, 2016, 08:09:11 AM »
http://www.partzilla.com/parts/search/Honda/Motorcycle/1999/GL1500CT+A/WIRE+HARNESS/parts.html
#12 behind center cover
« Reply #3 on: August 10, 2016, 08:40:27 AM »
Thanks.
Its easier to see that flasher relay if you take the other (left) side cover off.  I just did and man was it dirty in there, so I thank you, gave me the opportunity to remove the overflow bucket and clean it and all the gismos and wires.  You can actually see stuff in there now!
Its one of those little black boxes.  I think its the farthest one away (to the right)
« Reply #4 on: August 10, 2016, 09:03:41 AM »
We had one in the underground tunnels between the dormitories and the dining hall a bunch of times.
He like to wear bright orange pants.  This was a poor plan.   (well, the whole thing was a poor plan, but the pants were kind of a giveaway)
He was a rough character, three gals tackled him down and held him for the constabulary.  (You messed with the girls jock dorm at your own risk)
(sorry, wrong flasher)
« Reply #5 on: August 10, 2016, 09:14:29 AM »
You are going to have to rewire the flash indicator - w/o doing so you will get 4-way flashers instead of a turn signal because of the way Honda wired it - using the opposite side bulbs as the ground path.  Or you can buy a kit from Custom Dynamics.  I wired my own using 2 LED's inside the flash indicator instead of a bulb (LED's are diodes - one-way current gates). The way I set it up, my flash indicator also tells me if my taillight bulb is working. See https://www.customdynamics.com/pdf/MDK%20Tech%20sheet.pdf
« Last Edit: August 10, 2016, 02:18:50 PM by MarkT » Logged
Jruby38
Oxford Mass.
« Reply #6 on: August 10, 2016, 11:34:48 AM »
Thanks Mark T for the explaining.  The hell with it, I am going to just let them flash fast for now.
« Reply #7 on: August 10, 2016, 12:20:17 PM »
Fast flash is likely a bad bulb or a grounding issue somewhere not the flashing relay anyway.
rhinor61
Northern California
« Reply #8 on: August 10, 2016, 01:19:50 PM »
Chris..
the original post says he is install LED turn signal bulbs.
Thus the need to change the flasher or add resistors.
John
John
Northern California
1998 Valkyrie Tourer Black/jade
VRCC #28001
« Reply #9 on: August 10, 2016, 01:36:52 PM »
u need a LED compatible 3 pin Motorcycle turn signal flasher plug assembly for Honda. the oem flasher plug is not std.
I think this is the one needed.
http://www.lockhartphillipsusa.com/LP-USA-LED-SPORTBIKE-FLASHER-RELAY-HONDA-KAWASAKI-YAMAHA.html
Jruby38
Oxford Mass.
« Reply #10 on: August 10, 2016, 02:52:17 PM »
Thanks 98Valk, looks like its the way to fly. I hate buying stuff on the web vs going to autozone where you can see it.
« Reply #11 on: August 11, 2016, 10:59:47 AM »
http://www.customled.com/products/elfr-1-electronic-led-flasher-relay
Thats a direct replacement if you're looking to slow down the flash rate when installing LEDs.
Jruby38
Oxford Mass.
« Reply #12 on: August 11, 2016, 11:44:00 AM »
Thanks Patrick......
kahnma
Austin, TX
« Reply #13 on: August 11, 2016, 06:22:54 PM »
I just wanted to verify, which is the correct link? Does the Valkyrie require the 2 or 3 pin connector? The custom LED link is 2 pin and I think the link to lockhart is 3 pin.
Thanks!
2001 Valkyrie
2014 KTM 500 EXC
« Reply #14 on: August 12, 2016, 04:17:23 AM »
Thanks!
special 3 pin.  there is actually out there an adapter cable which allows a standard 2 pin flasher to be used. I bought one on ebay, the guy couldn't remember who made it, if it is still made is another question, he had it on his Valkyrie.
« Reply #15 on: August 12, 2016, 08:47:06 AM »
I had the same concern when it came, but, its plug and play. It works.
Thanks!
I had the flash rate slowed down to an almost acceptable level with the original flasher by changing front bulbs to higher cp. But, this one slowed them even more.
« Last Edit: August 12, 2016, 08:50:27 AM by Patrick » Logged
Colin
My old job
Orba, Spain
« Reply #16 on: August 12, 2016, 09:12:13 AM »
You don't actually need at 3 pin a 2 pin will do but you have to make your own connector to the existing loom. 2 pin are generally cheaper as they are universal.
Colin
VRCC Espana
My Bumble Bee re-build
